I've just been driving back from Heathrow in the rain and I got of at my junction to find the car wouldn't pull away as quick as it normally would, its like the turbo's not kicking in until after 2000rpm.
However, this behaviour is sporadic as I've just popped down to the shop and it would intermittently pull as I'd expect.
The intake is directly behind the grille and last time I stripped the top of the air box off, the inside of the pipe was damp.
Car is a 2002 Mk VI 1.4TDCi Fiesta.
Could this be caused by water in the system & how should I combat it?
After market filter on the front of the intake pipe?
Re-position the intake?
). I'm not sure bad seals would cause it to go into limp mode as the limp mode never kicked in until the dreaded night of driving home in torrential rain!
but it's just a diagnoses, not a fix. If the problem goes away with it unplugged it's the MAF, replace it or clean it and find where the water is getting in.
