It's not a fault. Just be thankful OCUK are providing any cover on it at all
It really is, I can point you to more threads from Gibbo stating it is, although his RMA manager has a different view point (lack of transparency). I'm not going to be thankful, I'm a paying customer, just as others are. I'd expect any card that's advertised as quiet, to be just that. No where in any of the documentation does it state that coil whine should be expected and to be the norm..
Not all the other cards whine, some don't do it at all, some do it a little, some a little more and some sound like a scratched record.
Anything that can be easily heard we consider a fault, but mild coil whine is quite normal on high-end VGA cards, but is normally only present during benchmarking when FPS are very high.
Also most coil whine calms down at a few days of usage, a tip is simply set Heaven running for 48hrs solid a stock card with fan at 100%, that cures most of them if they are noticeably loud.
Coil whine is a fault.
Surely you'd send back as a fault as then your shipping is covered???![]()
You mentioned stipulations with monitors, such as backlight bleed.
What about a GPU with coil whine? I never did return a GPU for that reason, but I'd DSR it rather than return as faulty. Would this now be faulty?
Yes of course we class that as a fault.![]()
