***The Vapers Lounge***
Status
Not open for further replies.
Hey thanks for your reply gregg :)
To be honest I've lost a lot of vapour and the throat hit !
I'm going to follow your advice and perform some maintenance on my vapouriser :)
I will probably also go ahead and buy a better vaper that X2 recommended a few pages back :cool:
Once again cheers for all the help guys
Watch the Squape R clones there seems to be some debate on quality the emetal coating on the desk and chimney. ;)
It needs replacing bud. They not meant to last that long
The lad I have bought it from is pretty savvy and has loads of stuff he never uses . He says the quality is excellent and he laid it flat when it was full and it does not leak so we will see but Ive had a few things off him and they have all been spot on. He had a couple of different tanks for sale and advised not to buy one of them as he had problems with it so I trust him
Well I purchased a clearomiser over the counter and it's brought my vaping experience back to life :cool: Cheers for the help guys .. I didn't realise how quickly the kit depreciated!
Sounds good sorry to put a bit of a downer on the Squape, I have one with a glued in slighty leaky tank but if I keep the juice below the top part of the window it only leaks when the atty is upside down.
Cheers
Treating myself to new apv and tanks at Xmas tired of the button issues with my zmax v5 have decided to go with nautilus tanks as friend had some with the BvC heads and was excellent flavour and overall vape. Spotted an apv I like the look of but tried looking on the net and YouTube but very little info out there that I could find hoping some of you are better at searching then me :). Its an s-body ezdna30-2 I like the form factor in terms of holding while vaping and pocket friendliness too many times my zmax fell out of pocket and 30 watts more then I'll ever use not into big clouds. Tried another friends vamo Mukey which similar and how I know it will be comfortable for me but not got fond memories of vamo's stripped threads on three bought plus I want a more regulated vape . So anyone know anything about the -2 or have any advice with the nautilus tanks.
Cheers
No bother I would rather know about it now than have my gourmet juice line my pockets :D
Anyone try vapecrate? The starter 3x15ml bottles for £12.99 may be worth a go then cancel before the second one turns up and it goes up to £25
Spectrum Vaping are doing a 30% off sale on their liquids using the code: VENDOR30
Just ordered a 30ml Blush, 10ml frozen berries, 10ml sweeney todd and 10ml spearmint for the wifey for £16 recorded delivery.
I hope it comes soon as I have cheap rubbish liquid including digbys minging 'the king' at the moment, plus I broke my new Smok RBST. Stupid thumbscrews!
Fancy swapping your Digbys King for a spider venom from vapemunki? Hope Im not wrong in assuming you dont like it? I also have a Limerick key lime pie
Got to love Simon at Scopes e Liquid.
Placed an order Tuesday at 4.30pm - at 5.30pm got an email saying "Your order has been marked as Shipped"
Arrived yesterday, amazing sevice tbh - I have been shopping there for about 18months. Brilliant
Got some lovely VG Heavy juice to drip whilst I am on my jollies tomorrow!
Hey oldestgregg, From a 10ml bottle I only have about 3 or 4ml due to having little choice but vape it. If you would still like to try it then I will gladly post it to you for nothing. Just send me your details if you want.
V_R, how are you finding the mutation-x?
I'm finding it very very airy, even with half of the airholes closed off!
For that reason I keep being drawn back to the plumeveil. If I could get the airflow from a Stillare V1 coupled with the vapor production of the plume, it'd be the perfect RDA :p
The Doge is going unused at the moment, there isn't anything special I get from the vaping experience.
Just received 3 bottles from vapegreen, 2 of them virgin vapour
Is it suppose to look like a 50/50 mix? Its not thick at all compared to the other 100% VG juice i have.
Exactly the same viscosity as 50/50 juice.
I'm still playing around with my igo-w, just can not find a build that works. Half tempted to get another RDA and try it.
However perhaps dripping is just not my thing...
Welcome back lol. :)
I like it so far, usually close off about half way, maybe a little more. Does give off epic clouds though! :D
I aint a dripper fanatic like some so I cant really compare it to others.
I'm yet to try a Plumeveil, Would like to though..
Thanks, had a bit of a run in with some of the MM rules that I wasn't aware of. Oops!
You'll love the Plumeveil, I run what would be classed as extremely low ohms on here with the RDA and the clouds are fantastic. There seems to be no compromise between flavour and vapor production with this RDA even at low resistance.
Would definetly recommend, I use it without the delrin airflow control in the top, and have replaced the entire cap with a 'wide bore' PMMA top cap, hits like a train! :-)
A range of 25 amber glass bottles and pipette lids arrived today (10 upto 100ml). Hopefully adding a touch of class to the DIY juice mixing :p
Status
