- 28 Sep 2014
- Scotland
http://techreport.com/news/27228/this-mini-bay-trail-pc-is-the-size-of-a-thumb-drive
$70 = £43.49 + £8.69 VAT = £52.18 for a HDMI Mini PC stick with quad core Bay Trail CPU, 1GB RAM, 16GB flash storage, Wifi, Ethernet, MicroSD and 2 micro USB 2.0 ports that can run either Windows, Android or Linux.
The higher end G with 2GB RAM and 32GB flash storage probably will cost $99 = £73.81 with VAT.
This will be much easy way to connect to your HDTV as cheap HTPC, media center or watch Blu-ray movies with external USB Blu-ray drive. You can connect USB Hub to it and use 4TB hard drive in USB caddy.
If OCUK or ebay ever stock G version then I would buy one in a heartbeat and install Windows 10 on it.
