Vote for cloud9. Never heard of an underlay to match a carpet... The family member that fitted the carpet is a carpet fitter and mentioned nothing if the sort. He was happy I had layed it and stapled it.
For the underlay we used double sided tape, along the floor where the joints will be then stuck the underlay on top.
Thickness needs to be correct this is classed as matching carpet with underlay the same with type of carpet you choose and the room type.
If your fitter seize all this doesn't matter then he's not great at his job.
That sounds like a right faff I don't know any pros who would go that far!
Thickness of underlay has nothing to do with thickness of carpet it's all about comfort underfoot and durability as for certain carpets for certain rooms again that's a nonsense you can put any carpet anywhere it will just wear differently!
A good carpet fitter wont charge that much more for underlay plus they pick one that is going to match the carpet you choose so you wont run into any issues when fitting.
So many people think it's better to save few £ by doing it them selves really it's not worth it.
That looks great, i need to redo my hallways and stairs.
Ive never done carpet before, and was looking to do the underlay myself to save some money before getting the carpet fitted.
A couple of questions suitable for this thread. Do you fit the same underlay to stairs? and is it best to keep it in largest sections as in having the hall all one piece ?
These guys are ace to deal with.
Personally cloud9 cumullus 11mm is used throughout my house, great stuff!
Did he know the difference between short, medium and long pin gripper?
Medium would be fine
