Does anyone here use vintage hifi gear ?
I recently unearthed my Dad's old gear, which seems to be quite well regarded and collectible these days, and was wondering if it was worth having it serviced to use myself, or whether to sell it and get something current.
It is a Garrard 301 turntable, SME12" arm and an Ortofon SPU-GT cartridge (bit of a monster..).
Your dad bought some very hi-end gear which is still sought after today. As with all things vintage though, condition plays a massive part in the value. The only way to be sure that the gear is still in good working condition, and hence to gauge its value, is to have it appraised and serviced by an expert in the field. Garrards use an idler wheel to drive the platter. The wheel is rubber and won't last forever. The motor, drive electronics and the platter bearings are the next things to have a look at. Finally the rubber mushrooms that act as suspension.
301's are a bit like owning a classic car. The condition can range from conquers condition down to a complete basket case. Fully restoring something at the "needs some attention" end of the scale can set you back a grand. Selling the deck "as is" might yield as little as a £150. It all depends on condition and the amount of work (read as money) required to bring it up to standard.
12" SMEs are nice but not particularly rare. Ortofon SPU-GT's are nice. However you'd need to have the state of the rubber suspension as well as the condition of the diamond checked before letting it loose on any vinyl.
If I was in your shoes, I'd invest £200 and have the deck serviced and appraised. You'll have a better idea then what you've got and its potential value.
http://www.classichifi-shop.co.uk/ If it's in decent running condition then you'd be hard pressed to buy anything new south of £800 that would equal it.
If you're looking for an alternative deck that's plentiful, inexpensive and easy to set up and use then one of the Regas (Planar 2, Planar 3, P2, P3) or a Pro-ject from the usual used sources will set you back anything from £100 to £500 depending on model, tone arm, cartridge and condition. A dealer service and set-up would cost around £50-£80 with belt and oil.
