- 9 Apr 2012
Stay away from Simply Electronics. Throw your money down the drain instead. You have a better chance of refining the money from the water than getting a phone from them.
I ordered mine on an £18/mo contract with mobiles.co.uk - £432 total over 2 years
Otherwise you can get it from mobile phones direct SIM-free for about £335.
Mine should be delivered tomorrow, but not likely to have a case for a few days at least![]()
Anyone experiencing data connection dropping out then not returning until the phone is rebooted?
Only noticed it over the last couple of days but it's becomming very annoying. Seems an odd thing to happen, suspect it might even be network related so will probably wait a few days. Failing that it looks like a reset is in order as a first port of call
I am on the Three network and this always happens to me. I have to put the phone in to flight mode and then take it out of flight mode to fix it. Sometimes the data connection would start working itself after a few minutes. Very annoying, but come to think of it, it has has happened on all the phones I have had I thinkAnyone experiencing data connection dropping out then not returning until the phone is rebooted?
Thanks. I never knew of this fix.Are you with Three by any chance? If so, fix that here.
It was driving me nuts so started diving into the service menus - thankfully the setting sticks even after reboots.
I would recommend buying directly from Amazon and not from third party Sellers.Not letting me order from mobilephonesdirect, cant check out i just get a web page with a error on when im logged in so thinking of buying off amazon from expite electronics anyone ordered from there before? Ive never ordered off amazon before. What are they like for returns if theres a fault with the phone??
