Crossfire R9 295x2, PSU?
31 Aug 2013
Hey guys,
Basically I have one 295 in my setup just now but was thinking of adding another for ***** n giggles and was wondering if my PSU is up to scratch. It's a Corsair AX1200i
Current set up is:
Core i7 5960x
ASUS Rampage
32GB Corsair (fast ram)
1TB SSD
Cheers guys
Here's a wee pic I took. Painted the R9 295x2 Matte black as the silver was a bit ugly.
[/url]
free image hosting[/IMG]
Jesus.. Gonna think about this for a bit before I buy. Basically kind of wanted to go all out and buy a PC which is future proof for a good couple of years.
Seems like a Corsair AX1500i is my best bet?
Do you have space for a 2nd PSU so you can connect the switching wires of the 24pin plugs together (so when one turns on so does the other) then just have the PCI-E cables powering a single R9 295X2 on its own.
Then you just need a 850W or so PSU to run the 2nd gfx card.
@Shivy
Well for a long time I've always bought Corsair PSU's as they seem to be top notch. Also, there must be something to justify 150 smackeroons. I think the Corsair has 10 year warranty as well, which is nice.
@ stulid
No space for second PSU, as you can see in the pic I moved the PSU into the second space so the 295's radiator can sit in.
Two 295X2 for that res.
You mad bro.
You also need to be careful of the PSU with multi 12v rails as you need to make sure that each individual rail is powering a single 8pin input on the card (or something like that) and that each rail has a certain amount of amps.
I'm not 100% on the AX1500i but on that PSU I just posted (which seems to have been deleted for some reason) it is made by super flower who are really great PSU OEMS. Also has a 10 year warranty and a bit more power :)
You mad bro.
Aye, I understand that it's overkill for that monitor but I can see myself in the near future upgrading to 4k.
To be honest I'm kind of thinking twice now about it, there is 100 quid off deal atm but changing PSU as well and finding a mount for the second radiator could cause some issues.
I understand you want to future proof, but all this effort of a new PSU, another GPU & whatever else you aren't going to see any gain what so ever.
The 295 is a power horse even at 1440p!
As above, you cray. Decent performance scaling generally stops at 2 or 3-way CF/SLI and drops off steeply at 4 unless you're doing 4K, 1080/1440p surround etc.
