Ah that's not too bad Gibbo.
I was kinda bad though.... I just plonked down 2x reference 980s instead. Because who likes food and warmth anyway? XD but on the bright side I bought it from yourselves sooooo. It's win win for you XD
OcUK are the only place I found a 980 South of £420. I did almost get your OcUK one for £409 but Zotac were offering 5 yr warrenty on theirs and that seems to help when reselling later (ppl always want to know about warrenty, when I sold my 780ti that was the most common question lol). Anywah it's great that OcUK got it shipped out today, I thought I'd missed last post ^_^Gibbo, how does the reference cooler on this card differ from the cards that the reference cooler is based on, e.g. the cheaper Galax, Palit and EVGA cards?
Is there much in it?
It is not even close!
The NVIDIA cooler build quality is in a different league, the thermals and noise levels are also much lower.
Then just look at it, no offence but one looks like cheap junk and then you have the NVIDIA with its premium looks and that gorgeous NVIDIA backplate.
For me the cheapo Galax and Palit ones do what they say on the tin but they are cheap because the cooler is cheap, it is that simple, but it does what it says on the tin.
The NVIDIA built card has a premium cooler on it, backplate and the components are of higher quality. Bear in mind a lot of the 970 cards are built on 760 PCB's to reduce cost.
Our 970 is on a 970 PCB! No cost down!![]()
Hey gibbo
I noticed you posted that you had requested that the coils be plastic covered etc
So is this still the case?
Yes that has being done, different plastic containers which the factory reported back on saying it helped reduce noise and eliminate it in some cases.
Looking forward to them arriving, it is the ultimate 970 for 2-way SLI in small cases and 3-way SLI.![]()
I really need to stop coming to the OcUK website, I always leave poorer
hehe.Does he fancy a 3 way? Wow easy tiger
I have two 970s ready for the bay nowI really need to stop coming to the OcUK website, I always leave poorer
hehe.
Those 970s sound epic, I am feeling bad I am missing out, but hopefully the 980 references will be more or less the same quality. Obvs not sure about coil whine but fingers crossed...
So how will this custom 970 reference compare to the OCUK reference 980 (the £410 version)? Are we talking like for like other than the obvious fact one is 970 and the other is a 980, or is there more to it than just that?
Because of my case and pc location the ref 970 blowing out the case would suit my needs better
lol.Yes that has being done, different plastic containers which the factory reported back on saying it helped reduce noise and eliminate it in some cases.
Surprised they sent you one to check/bench etc
Or have they and your keeping quiet![]()
Are these still due in today?
