Spec Check if you please.
Don
23 Oct 2013
Guildford
Chaps have my basket full just awaiting OcUK to have the case and cooler in stock before I buy, just want a spec check to make sure I am not missing out on something amazeballs.
Can't post the basket the normal way as I'm at work.
I already have a -
EVGA 750W G2
Samsung 250GB EVO
Peripherals
OS
Ignore the stuff with the red line as this is for my sons build who is getting my FX8320, MOBO & GTX 780 SC.
Anything worth changing? Only thing I can think of is the SSD & RAM but I am open to suggestions.
Josh
I'd go with the 4790k & UD3H BK bundle. If you've not already seen/heard gigabyte are giving a 3 year upgrade warranty which means you can trade your old motherboard in for a new skylake/skymount. That bundle also works out cheaper.
The rest looks bang on. The SSD could be dropped to the mx100 to save £20+ but the evo is an alround better drive. Worth the extra In my opinion.
So if you got another 840 EVO you are going to RAID0 them up for epic throughput?
I considered it, I just need MOAR space for my games really.
I like the Colour of the SOC Force though...hmmm will check out the bundle now.
Will look into that then cheers Doomed.
The CPU cooler may be in stock this week but the case is open ended, looks like I may need a new case then as I want to order in the next couple of days as some stuff is "this week only"
Ideas?
750D is the only one that springs to mind as I have a 300R at present.
Was £200 too much dolla for a case?
Doom reminded me that NZXT do orange+black H440.
I'm tempted by it, still looking around, might keep my 300R and H80i as I am getting a new H80i via RMA.
I want a full tower but it isn't a priority 1 upgrade unlike the others.
970 is defo on the cards, looking at the EVGA SC ACX one as I've had the 660 SC, 780 SC.
