Caporegime
- 9 Nov 2009
- Planet Earth
What RAM do you have?? Is it DDR3 and what sticks are they??
Basically, the shop you've bought from isn't very good.
I bet the PC was overpriced too!
Its a pretty compact case - it will only take a single full sized HDD,but it will do the job I suspect.
Edit!!
When you say camera?? How many cameras and what software do you use??
If you are recording footage it would mean you are thrashing the HDD. How multi-threaded is the software?? Maybe try and get a Core i3 instead??
So maybe the Antec case will be a better bet as you can plonk more storage in.
Edit!!
Maybe an Elite 120 or Eliet 130 case??
It was £259 I think at the arse end 2012. To me, that's not very expensive for a desktop, but that's because I don't really like crap PCs.
EDIT: What I mean is, I'm not sure I've ever spent that little on a PC.
No, no recording - it's a live stream, sort of like a posh webcam, used for taking centration data from somebody wearing a pair of spectacles. It's an opticians.
It's just a crappy PC then, right?
You could do it even cheaper if your not worried what it looks like.
YOUR BASKET
1 x Intel Pentium G3220 3.0GHz (Haswell) Socket LGA1150 Processor - Retail £41.99
1 x Asrock H81 Pro BTC Intel H81 (Socket 1150) ATX Motherboard £32.99
1 x EVGA 430W 80 Plus Power Supply (100-W1-0430-KR) £31.99
1 x Aerocool V3X Devil Red Edition Midi-Tower - Black / Red £14.99
Total : £131.56 (includes shipping : £8.00).
Reusing your existing memory and HDD.
This is of course if you are up to building it, reinstalling all the software etc. If you are not, then I would suggest buying a complete machine. This may be the best option, that way you cannot get blamed every time something goes wrong.
The business owns it's own copies of windows, so that should be okay, right?
