 - 26 Jul 2014
Plus the fact your front wheel isn't in the line and is breaking the line too.
			The photos show that they've not lost anything as other cars are parked behind the OP's car...
haha, have you ever seen the website you park like a see you next tuesday?!
pretty sure this will feature on it.
If you can't park it, get a smaller car![]()
	I'd be totally agreeing with you if I'd parked like this:
But it's not quite the same, is it?
Not only is the boot of you car intruding into the 2 bays behind it, the passenger side front wheel has crossed into the hatched no parking area to the left.
So what should I have done? Park further forward and have the front of my car jutting out into the road?
1) No they're not.As far as I can see:
1) My wheels are all within the marked bay area.
2) The front of my car is aligned with the front white markings.
3) The parking bay is on a corner, if I'd parked further forward there was the danger that other cars turning could damage my vehicle.
I'm intending to appeal to PPS directly first, and then to IAS, highlighting the points above, does anyone have any advice which would help?
If you need to use three parking places, then buy three parking tickets.
1) No they're not.
2) No they're not.
3) Was that the only parking space available at the time?
You had to place your car within the three white lines, not within three parking places. If you need to use three parking places, then buy three parking tickets.
You're stuffed. As other's have said, your car has to fit within the bay, not just the wheels. As you can see from the picture, a car can have wheels within one space and still be preventing another driver from using the adjacent space. If you'd left the front sticking out, you probably still wouldn't have been within the bay. Your car doesn't fit in the parking spots in that car park.
You might be able to argue the terms of the contract, the cost of the claimed losses, etc, but I doubt you'll get away with claiming "my wheels were in the marking, it's not my fault my car is too huge and takes up three spots anyway".
I did read a while back that a lot of older parking places were getting their bays redrawn because today's larger cars just don't fit into the spaces anymore.
