First OSX i haven't upgraded too within weeks. Think I will wait for .1
Indeed. It has way too many issues.
OS X will use as much RAM as it can. Unused physical memory is just being wasted. As long as the memory pressure graph is greenish all is good.
I've got 16GB, it's showing used as 14.52GB with only 10 tabs open in Safari, Mail and iTunes open. If an application demands some memory OS X will free up some inactive memory and allocate it.
On my own rMBP. I've used the exact media to restore my own Macbook too.How did you create the installer?
Yes.SSD set to GUID Partition Table?
No, he means how you created the image. On older versions of OS X (Lion and earlier IIRC) you used Disk Utility, using InstallESD.img as the source image. Now there is a dedicated install utility, createinstallmedia, which you use in Terminal.On my own rMBP. I've used the exact media to restore my own Macbook too.
So many of you will notice how terrible Spotlight can be when it comes to anything beyond searching your Mac. Worth trying this! http://flashlight.nateparrott.com
EDIT: OK, so MacStories have covered Flashlight and mentioned LaunchBar, which I never had heard of before. Looks like a more complete solution but doesn't integrate searches like Flashlight does, so it's really down to personal preference and requirements. Flashlight unfortunately only supports US shopping and weather at the moment, so aside from the quick Google searches, it isn't quite there yet.
EDIT 2: So Flashlight has seen updates in the last couple of days and you can really see where it is going. It has an API like Launchbar does, and there's already some good stuff. For now I'm sticking with it purely due to the integration with Spotlight, as it is looking extremely promising.
10.10.1 is out
7 hours to download 300mb update. Apple really need to fix there server game :/ can't seriously expect this to be acceptable.
I've been using Alfred for a couple of years now and far superior to Spotlight pre Yosemite and still superior post Yosemite.
One of the first apps I install.
Ah, I misunderstood, I used createinstallmedia in Terminal.No, he means how you created the image. On older versions of OS X (Lion and earlier IIRC) you used Disk Utility, using InstallESD.img as the source image. Now there is a dedicated install utility, createinstallmedia, which you use in Terminal.
I upgraded to Yosemite yesterday and ever since then my 360 Controller stopped working for my MB Pro....
