- 6 Jan 2013
- Rollergirl
If I order something online for store pick-up, can I still return within 7 days for any reason?
I thought* actually if you pay remotely (online, phone), then you are protected by CCR. If you pay in store, you aren't.
Am I wrong?
*ie. not backed by any reading of the actual regulations so don't kill me![]()
It's not really aimed at "try before you buy" though...
It really is if you think about it.
Shoes and clothes maybe, which you would normally try in a store.
You wouldn't whip out a 50 inch TV from the box in Argos and ask to try it.
It's designed to allow you to buy at a distance in the knowledge that you can get a refund of you are not satisfied with the quality.
That's what I want to do.
No, it's designed to give you the same opportunity to inspect goods as you would in a bricks and mortar store. Like has been said, whipping a TV out of the box usually isn't an option.
And seeing a display model, is that an option?
The exact model and make you are buying? Very often not.
I disagree. When I looked for a TV I hunted around online then went into Richer Sounds so see which set out of the narrowed down choices I preferred. This can be done in so many stores too as they tend to have most of the sets available on display and in the case of RS you can often ask to view the set if they don't have it on display.
