Very nice, large photo though!
EDIT: Ah, you caught it!
I presume the left edge doesn't go to a wall and it just finishes off to a straight edge?
Err. If you're moving tomorrow (today?) don't you think you should have started packing already?
Yep, an old c7 tri channel kit from one of my x58 rigs, iirc 1.65v, 7-7-7-24 at 1.65v. One stick might be dead. Ive got no way of testing as the heatsinks on my two rigs prevent the use of reapers due to their height. Only found the kit last weekend, and tbh its gonna be chucked in the bin. No use to me anymore sadly.OCZ reaper dims you have there?
Tbh mate ive no idea if any of the sticks works at all, i only have one x58 rig now that runs tri channel. But due to the size of the heatsink it uses, testing high dimms like reapers is very hard, (its a 24/7 server, rarely turned off) and impossible in my spec in sig as it uses an alpenfohn k2 were low profile ram is a must. Chuck me over your address via trust and you can have the kit. I dont want anything for it. Should be ok with the moderators on here.Send to me if your gonna bin them, guess 4GB still works.
