What kind of video card are you using to power the display? I've a Geforce 770 but I'm worried that it wouldn't be able to handle gaming at 3440x1440!
I am using gtx 780ti . 770 is enough if you don't turn all the setting to max.
if the source is 21:9 then it will fill up the whole screen and just tested your youtube link to confirm.
Fantastic, could you possibly confirm with Netflix too if you have it? Those are my only real concern, other than that holding out for DP 1.2a for FreeSync goodiness. Money all set aside for these![]()
Just received my 34UC87, however it didnt come with a UK plug.... came with a Schuko Plug i believe its called at 16A 240V, another 2 days of waiting now i assume since its past 5pm and i just sent the email, wont receive a new uk cable till Thursday, think i might receive it tomorrow Gibbo ?
Someone mentioned this a few posts ago and so did i, guess it wasn't noticed...
Will http://www.overclockers.co.uk/showproduct.php?prodid=CB-092-OK work in place of the German cable ? The german plug end states it is 16A 250V but that UK plug cable is a 5A Fuse
Get in touch with CS they will send you a UK plug out free of charge as should have come with one.![]()
