Hi there
AMD have extended the mega discount on the 295 X2 until end of next week for us or when the stock is gone, whichever comes soon.
Of course we have now learned there is nothing to stop AMD from maybe repeating this in the future, but right now once they withdraw their support our price shall have to increase back towards the £700 mark.
So might as well grab them, though I can't be 100% sure as you never can but I seriously doubt these will go cheaper, I mean it is now less than buying a pair of 290X which makes it a great buy:
MSI Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £509.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 3yr
Was [£699.95] Inc. VAT
Only £509.99 inc VAT.
ORDER NOW
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 3yr
ORDER NOW
