Hi all, I recently bought the Samsung 32D850D 32" and have found it to have an issue when PC gaming.
When in 'outside enviroments' the monitor flickers white frequently (there is also very faint vertical lines when the flicker occurs).
Interestingly, when in caves and dungeons there is absolutely no flicker at all.
I have literally just plug and played with the monitor, so no software updates or settings have really been played with. So I am wondering if there is something I need to do to fix the issue.
I have connected it via HDMI (I originally connected it via DVI and the issue occurred then too) and have set it to the native 1440 resolution.
Looking around the internet regarding flickering, while I found little info on this specific model, I have seen solutions with other TVs/Monitors that involved:
Replacing the Power cord
Disabling Deep Color
Reducing Contrast to 0, put brightness to 100 (but that seems like a work around to the fault rather than fixing anything)
An example of the issue is here:
Interestingly the guy had the same problem with the BenQ.
I haven't had the chance to test any solutions yet, but if anyone else has had flickering issues on this or any monitor and can offer solutions, they will be appreciated. Currently looks like it may have to be returned, it certainly seems flickering is not an uncommon issue
