***The Vapers Lounge*** 2.0
Status
Not open for further replies.
@slick rick- I thought they were 25? Im probs wrong as usual but I thought thats what the 25 stood for? All I know is they highly regarded and drop offs pretty good in my panzer although TBH I dont have much point of reference as I have one purple efest and 4 panasonic greens
Quick google fu shows they are 25a. My mate at the vape shop says he switches between those and vtc4s' and loves them.....or as much as any one man can love a battery I suppose!
You are probably right and I have heard they are good batteries. I think it might be the Sammy's that are underneath the Efest purple wrap, I cant remember for sure, it might be a LG.:confused:
The 25r's will be great in most applications but I would not use them for super sub ohming (that's not something I advise with any battery though being honest).
The MVP has been around along time and has become a staple of the vaping world (for good reason, its a tried and tested device).
The istick is a relatively new kid on the block. I have tried both devices and each have pros and cons but on balanced I preferred the iStick.
As with everything different people like different things, so while we can recommend what we like, your opinion might differ. :)
Thanks for the adivce. I have held both device's and really like the look and feel of the Istick over the MVP. With the Istick being a lot smaller and only being 400Mah difference in power but a lot cheaper im more in favor of the Istick that way.
But as always, the MVP being more reliable and being Tested over time im swayed that way too HAHA!.
I think ill go for the Istick though as i think it will be a case of like you said more power if its needed.
The iStick is a very nice form factor, so compact.
And the price is the same as a few 20 packs of cigs so wont take long for it to pay for itself. ;)
Let's face it, everyone who vapes has a use for the istick, its just so good for its price.
Innokin iTaste VV4 is coming out soon..
Take that slowtech! I ordered 35ml of riptrippers blueberry and custard from US on dec 7th and its just arrived super late post. Five days from the US is top class
6v though? Cant see the battery lasting too long as my segeli 100w drains pretty quickly with 2 18650s in if you going for 30wts.
I know its only 25wt but you get the idea :)
Ah, so it's not just me? (I use it at 30W)
Down 19% since this morning with fresh batteries fwiw.
I guess when you're used to an MVP2 lasting for days, it seems quick.
Thats the nature of more power though isnt it dude. I vape my kayfuns at around 17w and I can get 3 days out of it then but once I stick my big dripper on there at 30w+ it sharp drains them
What do you think of the Big Dripper Gregg? And is it a version 1 or 2?
I love my v1 but the v2 looks interesting with the window.
Version 1 mate. Its only a clone as a mate give me it to try and ive kept it :D
The only downside I have is the drip hole inside that feeds the dripper isnt in the middle meaning one side gets more juice. I dont even fill up the tank,I just use it as a normal dripper to try new juices really untill I get a mutation x for xmas
Mine is a clone too :) The authentic was next to impossible to get in the UK when it came out. The hole placement for the juice is the same on the authentic dripper, its a shame they couldn't put a hole either side to have one above each coil but I guess that would make it leak.
I love the flavour off it, really took me buy surprise how good the flavour was. :D
Status
