They're over a year old, were on my Raleigh which I bought in October 2013. I'm going to give them a ring but not holding out much hope.
Edit - just rang and only 12 months warranty. Only started using them recently. Oh well.
it is the "base" version for £99!the only difference between the base/elite is the GPS tracking afaik, the rest is the same when it comes to sensor/quality etc!
yeah, as soon as you plug it in and download the garmin virb software it asks you to update it, done it of course, no idea how unstable it was with original firmware but right now it seems to be fine - only a couple of hours worth of recording tho so it's a bit too early to tell!
that was 720p, 1080p is sharper and IMO for the price it is a great a camera!![]()
traffic on that road is really bad! yesterday was kinda "usual" it gets a lot worse and goes from bishops bridge road to brixton on REALLY bad days.. pain up the bum.
Joking aside it is quite cool. Can you make a hyper-lapse of it?
And all those hills![]()
Ahhh cool, what devices do you have yours paired with? Garmin 610/810? I actually don't have a Garmin but I'm using Garmin sensors (GSC10) paired to my phone (IpBike)... Although fairly sure I won't get the data overlay as the sensors pair with the computer and the VIRB uses data imported from that?
You deal with a ton more traffic than me - although I have narrower roads with predominantly stationary/stop-start traffic on my commute home with little/no space for cyclists...
Quite interested in what lights and high vis you're using (if you have the time to detail which/why/where) - same goes for anyone else really commuting in traffic/inner city where being seen is almost more important than actually seeing where you're going. All of my commuting riding is on the same roads mostly under street lights.
I'm slightly paranoid after being knocked off that I'm not visible enough!![]()
the way it works is -;
If you want to get the overlay and all that malarky do you have to manually sync/edit/whatever the video or is there a setting where that will happen automatically?
it's a bit tricky too.. say my yesterdays video started 2 minutes before I started logging my ride with my garmin so I had to set the gps point in the software to match the part of the video - not as easy as it may seem! especially getting the speedo in sync
not that it's needed really..Quite interested in what lights and high vis you're using (if you have the time to detail which/why/where) - same goes for anyone else really commuting in traffic/inner city where being seen is almost more important than actually seeing where you're going. All of my commuting riding is on the same roads mostly under street lights.
I'm having trouble eliminating a bit of play I have in the headset on my new bike that has developed over the past month. It's about 1mm of play you can see/feel if you rock it back and forth with the front brake on.
I've loosened the stem and nipped up the top cap several times but still have the same amount of play. Is it possible that the steerer has been cut just a smidge too long so it's not possible to compress the stem/spaces enough to remove the play?
To be honest I think you could be lit up like a Christmas tree, and still somebody will probably claim not to see you.
manual job sadly!it's a bit tricky too.. say my yesterdays video started 2 minutes before I started logging my ride with my garmin so I had to set the gps point in the software to match the part of the video - not as easy as it may seem! especially getting the speedo in sync
I'm mostly bothered about the map part of things to be honest. It would be really helpful for planning routes in future
Sounds like a faff though...
Ah, that sounds better. I have an 810 so I presume it'd hook up in the same way.
can be set as one of the training pages.Check that the top cap is not hitting the top of the steerer tube when you tighten. There should be 3-4mm of stem or spacer sticking up above the top of the steerer before you put the top cap on.
Also check that the star nut is not sliding up the inside of the steerer when you're tightening.
Thank you, I've just had a closer look and the top part which the cap screws into isn't sitting flush with the steerer, is that relevant or does it not matter?
