A white, Gray, Black, and a Black/Gray
But I seeIf you see four distinct shades, two white on the left, two black on the right, then you're in the clear. But if you only see a black and a white column, you have the problem.
I have a grey one
But I see
one white
one grey
one light black or very dark grey
one dark black
I have a grey one
I checked this on my HTC One M8 just out of interest and it seems this phones display is Full RGB![]()
I have:
Top left: White
Bottom left: Gray
Top right: Black
Bottom left: Dark Brown :S (looks like mud)
Do you mean Bottom Right?
This should look like a mix between Black and Gray.. Its this shade that gives you details in shadows in games etc
Try here also. http://www.displaycalibration.com/brightness_contrast.html
Move over the colours to change the background you should keep seeing all the shades.
Thanks....You should what you seeing is the correct way it should be.. I think they got mixed up when writing that bit.
You would only see two white and two black if your Colour was outputting limited RGB.
Four shades should be seen like you seeing.
This is a better test of BLB output. http://www.lagom.nl/lcd-test/black.php
If you are set up correctly (rgb limited output to rgb limited display or full to full) then you should see every shade above 0. if you see none, then your rgb full/limited settings need altering.if you see some of them, you've probably got your brightness too low.
I can see all except 1/2/3, this may be a brightness issue though as my controls have been broken by the latest AMD driver lol.
How is your display connected? if its DP or HDMI in AMD CCC think its under my digital flat panel.. Make sure under pixel format you enabled Full RGB..
It's a laptop screen.
Not sure about Laptops but does it have the pixel format in CCC??
