- 23 Mar 2011
i dont seem to have the rubber mounts that would have came with my case to fit the 2.5 drive to the base! what do i need to buy to fit the SSD without these?
thanks
thanks
Some sort of adapter,
http://www.overclockers.co.uk/showproduct.php?prodid=HD-002-OP&groupid=701&catid=2104&subcat=910
http://www.overclockers.co.uk/showproduct.php?prodid=CM-019-AK&groupid=701&catid=2104&subcat=910
http://www.overclockers.co.uk/showproduct.php?prodid=HD-027-OK&groupid=701&catid=2104&subcat=910
hopefully i have the right bits at home somewhere then! I did see i have a sata 6gbcable which i assume is for this?i dont seem to have the rubber mounts that would have came with my case to fit the 2.5 drive to the base! what do i need to buy to fit the SSD without these?
thanks![]()
