best way to remove artic silver 5?
23 Mar 2011
Got a new cooler to fit so will need to reapply the paste
Not done this before so what do i need to get?
Thanks!
Also the new cooler has a back plate to fit on the rear of the motherboard but my case does have a cut out for that
Does that mean i can leave it in the case of would you still recommend taking it all out?
Thanks!
http://www.overclockers.co.uk/showproduct.php?prodid=TH-000-AC&groupid=701&catid=27
If you have a cut out, then attach the backplate without removing the motherboard providing it's not too fiddly. Sometimes it's easier to remove the motherboard though.
Isopropyl/Isopropanol alcohol is also suitable, and can be used for many other cleaning tasks and can work out cheaper than a dedicated TIM cleaner.
At a pinch Nail varnish remover can also be used, although some are scented or have additives.
Thanks! Any idea where i can get these alcohols?
Also what sort of cloth should i use?
Ta
Chemist will usually have them.
I use cotton bud type sticks (made for PCB's), put a drop on the head and clean and repeat much easier than cloth as you can see where you are cleaning and take extra care around surface mount items.
I usually usual use one of the dedicated cleaners (Akasa TIM-clean, ArctiClean), the Isopropyl/Isopropanol will be cheaper but given that the bottle of TIM-clean I bought has lasted years I wouldn't bother about the price difference and the citrus smell is a bonus.
lol :) i went ahead and ordered the stuff from the first reply to this thread along with some compressed air to have a general clean up in there! fitted an SSD the other day and its a mess! may take it all out and try some cable management
