- 16 Jun 2011
They were just being over dramatic, it won't go pop.
Unless something possibly running a bit warmer is the same as something going pop!
What power supply do you have though?
600w
I cant find its dimensions
241.3mm.
Search "evga 970 sc blower" - one of the top results.
http://www.overclockers.co.uk/showpr...odid=GX-264-EA
but from my quick half assed googling, it seams a little loud. if you dont care about the noise, then this might be the one for you, but fan noise is important to me so I wouldnt have it.
then there is the proper "titian" style cooler
hell no get the ACX cooler!
why would you get a blower, your airflow isn't bad as proved by all the dust
there's a hole on the side the case right by the card and another ontop the case right?
Eh, now i'm conflicted.
this why you should read reviews instead of listening to the advice of random people on the internet lol
except my advice on NOT spending £20 for cans of compressed air, that was excellent
http://hexus.net/tech/reviews/graphics/74853-evga-geforce-gtx-970-ftw/
...not same card but same cooler
okay well the blower type are more for tiny cases or multiple cards
its not worth the extra when it will perform worse in your case
just my opinion![]()
I see. Screw it, ill go for the http://www.overclockers.co.uk/showproduct.php?prodid=GX-263-EA&groupid=701&catid=1914&subcat=1010
worst possible situation is ill have to cool my pc with extra fans and use diddums advice.
Get the galax infinity black if it fits. Best 970 for the money. One of the best coolers, backplate, built in a 980 board (so better components, but more power efficiant than regular 970s). No brainer...if it fits
http://www.overclockers.co.uk/showproduct.php?prodid=GX-010-GX
Just for the record, the blower I linked is perfectly fine. If it wasn't, EVGA wouldn't sell it. Simple as that. They're arguably the best brand available for Nvidia cards and wouldn't put their reputation on a cooler which doesn't perform.
I also had the same cooler for about 8 months on my GTX 770 and it worked a treat. Quiet too, although that's very much contextual.
Fair enough mate, it's a great card nonetheless, jist make sure you have a bit of ventilation in your case![]()
I had the Evga and tbh it looks cheap as hell and had mega coilwhine. Swapped it for a G1, has tiny coilwhine but is a solid card! Comes with a backplate and lights up.
Evga are ditching that card and releasing a revamped version as the cooler is only using 2 heat pipes! The fan is really noisy but only kicks in at 60C which was a nice feature, the trouble is to keep it cool then on in it needs to have high fan speeds which are pretty loud.
The card is plastic and doesnt really look like a £280 card, the Galax would be a better card all round but it does only have 2 years warranty.
