EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply
Should fit ok. Im using braided extensions on my superflower which is the same as the evga, (sf make the evga psu's).
Red/white/black extensions here to match my ROG formula board. Earlier pic prior to going sli.
Do they use "standard connecters" I.E http://www.overclockers.co.uk/productlist.php?groupid=1929&catid=1979
Looking for red ones:D
Are you looking for replacement cables ? Or just a few extension cables ?
I don't know if you have seen these. They are a full set of replacement cables for the EVGA Supernova G2.
YOUR BASKET
1 x CableMod E-Series G2 & P2 Cable Kit - Black / Red £69.95
1 x CableMod E-Series G2 & P2 Cable Kit - Red £69.95
Total : £149.50 (includes shipping : £8.00).
Was looking to get the G2 and some red cables. I cannot pay that amount.
Something like this then ? You get the 24 Pin and 8 Pin cpu cables as standard. You can then select either 6 or 8 pin pci-e cables to go with it depending on how many graphics cards you have.
http://www.overclockers.co.uk/showproduct.php?prodid=BU-013-SV&groupid=701&catid=1428&subcat=2664
Another option is the Bitfenix Alchemy extension cables
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1428&subid=2656
Extension cables will work fine with the G2.
Thanks lee32uk Thats Purrrfect:D
Now see sig..
Is it worth getting the 850 (70.8a) for one more sata port?
I'm thinking the 750w.(62.4A) I may get another 980ssc in a couple of years:eek: but for now I am happy.
Thanks you all:p
Now see sig..
Thanks you all:p
The 750W G2 will easily run 2 x 980's. Is there anything wrong with your current Corsair psu ?
No m8 it's just messy:confused:
I have been waiting for a while for Cosair to send me another HDD cage.
I have 3 HDD siting on my desk.Want to install them.
I have seen in the 750D thread the cases look good. But all are using modular psus. Plus it would be good to have a spare psu.
How do I post pics?
