Do they use "standard connecters" I.E http://www.overclockers.co.uk/productlist.php?groupid=1929&catid=1979
Looking for red ones
Should fit ok. Im using braided extensions on my superflower which is the same as the evga, (sf make the evga psu's).
Looking for red ones![]()
Are you looking for replacement cables ? Or just a few extension cables ?
I don't know if you have seen these. They are a full set of replacement cables for the EVGA Supernova G2.
YOUR BASKET
1 x CableMod E-Series G2 & P2 Cable Kit - Black / Red £69.95
1 x CableMod E-Series G2 & P2 Cable Kit - Red £69.95
Total : £149.50 (includes shipping : £8.00).
Was looking to get the G2 and some red cables. I cannot pay that amount.
Something like this then ? You get the 24 Pin and 8 Pin cpu cables as standard. You can then select either 6 or 8 pin pci-e cables to go with it depending on how many graphics cards you have.
http://www.overclockers.co.uk/showproduct.php?prodid=BU-013-SV&groupid=701&catid=1428&subcat=2664
Another option is the Bitfenix Alchemy extension cables
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1428&subid=2656
Extension cables will work fine with the G2.
Thanks lee32uk Thats Purrrfect
Now see sig..
Is it worth getting the 850 (70.8a) for one more sata port?
I'm thinking the 750w.(62.4A) I may get another 980ssc in a couple of yearsbut for now I am happy.
Thanks you all![]()
The 750W G2 will easily run 2 x 980's. Is there anything wrong with your current Corsair psu ?
@bigmac - our replacement cable sets would make your build look cleaner and minimize the cabling in your system!
