Also I've only really looked at the stuff on offer at Powerhouse fitness. As the prices seem cheaper than everywhere else i've come across doing quick searchers. Is there anywhere else i should look at (plates and bars are the biggest cost i guess)?
Hi all, I need a little help in chosing a multi gym!
I'm wincing writing the above line as I know that that poeple will now be looking for something heavy and blunt![]()
Allow me to explain, I have a medical condition which means I don't keep balance easily (think walking about drunk and you are partly there). This means that squats, bent over rows, deadlifts are a bad idea. I can bench press with a bar (spotted) but in general free weights are a bad idea on my own. I would consider a cage etc but its not a good idea.
I've been going to gyms on / off for years (work depending). When I go to the gyms even with trainers I end up with a reasonable amount of machine work and the odd bit of dumbbell work.
Now I've moved again and openly considering a multi-gym. Bearing in mind that I still end up on machines when down the gym. I'm toying with the Lifefitness or body-solid gyms which look reasonable. Any thoughts?
A Smith machine I guess?
http://www.powerhouse-fitness.co.uk/bodycraft-jones-smiths-machine-deluxe-package.php
Like a rack but "easier" to use.
Otherwise a "commercial" grade multi gym like this:
http://www.powerhouse-fitness.co.uk/bodycraft-x4-4-stack-commercial-gym.php
No doubt you could find cheaper but I'd imagine a decent multigym is easily £1k+.
I'd say something from Argos (V-Fit etc) isn't worth bothering.
Measured my garage today, it's 2.5m x 5.0m. So it's going to be pretty tight in there i think. Anyone else train in such a small area?
The bar, on the other han: it's difficult to tell with them because manufacturers/reselllers rate them differently and use different tolerance levels. If you're lifting heavy (which I know you are) I'd actully spend the money on getting a decent bar that will last... it is how you interface with the loads, so might well determine how much you like lifting at home. In other words: don't go cheap for the sake of saving money.
I lift (snatch and clean) in a converted garage that's 3m * 2m, so you'll be fine.
The actually kit? Not sure, but I've looked at getting that rack...The bar, on the other han: it's difficult to tell with them because manufacturers/reselllers rate them differently and use different tolerance levels.
Thanks man, looked again this morning when measuring the height and i think i'll be ok. Must have been weird training in there the first few times?
To be honest i suspect the cheaper Strength shop bar will be much better than the bars i've been using for the past couple of years (700lb cheapo bars with broken bearings - probably the same as the packaged bars that come in the weight sets from powerhouse, hence my reluctance to buy them).
Though i understand what your saying. The cheaper bar is only £90, so not a massive loss if i need to replace it in the future for a better quality/stronger bar (which I hope i'll need to strength wise).
The issue i've got is i need to stay under a budget to get clearance from the wife to do it. So the first initial purchase may have to be compomised slightly in some areas. Once I've got the base setup and some training with it, i'll look to add a few bits in.
The weights will hopefully last 10's of years, the rack and bench hopefully a few years at least. The bar on the other hand as long as it last the first year i'll be fairly happy i think (hoping to hit around 250kg deadlift and a 200kg squat next year).
Can anyone recommend some cheap floor matting?
I was looking at getting 2 of these:
http://www.powerhouse-fitness.co.uk/bodymax-6-x-4-x-10mm-commercial-rubber-gym-mat.php
The roof is about 7' so have to OHP outside and juggle my bench / squat rack when I DL. But it works fine and it hardly that much effort to move things around. If you can plan your exercises to match the setup of the room then it works fine.Sure do - my garage is probably the same size, has two bikes in it and leaksThe roof is about 7' so have to OHP outside and juggle my bench / squat rack when I DL. But it works fine and it hardly that much effort to move things around. If you can plan your exercises to match the setup of the room then it works fine.
Ah, yes - wife clearance. I understand that one.
Training in a wholy inappropriately-sized gym has ibeen interesting: I've put my head through a glass window (thrown back by a bad catch), butt hurled into a ladder (and wall), all sorts... but it's also meant I've got very precise at bar placement - it either works, or I bail. The amount of space I now take up is - for 98% of my Olympic lifting - around 60cm front/back.
One option I would suggest to "smooth" the capital expenditure profile of your investment is to get cheaper squat stands (admittedly this won't save you tooooooo much) that are only rated to 180-200kg. This will give you a bit of headroom and is a much cheaper thing to replace than a bar.
I went for some (I htink they cost £70 or something?) and yes - they suck - but they're fine for what I need. And it was my wife who suggested I get some bigger/sturdier ones.![]()
245kg of plates...that will last you a while![]()
Food for thought there on the smith. Used one a while back but will go and see if I can get on with one.
As for V-fit
I was considering something like this:-
http://www.fitness-superstore.co.uk/life-fitness-g4-multigym.html
With a 23kg weight addon it has ~96kg stack. More than I've ever got to.
Another one that seems interesting:-
http://www.fitness-superstore.co.uk/body-solid-g6b-bi-angular-gym-1.html
210lb stack with some doubler.
The body solid stuff seems to get good write ups. Looking at a LifeFitness as I have the R3 recumbent bike already which will probably outlast me!
