A plane is on a treadmill...
False.
They don't make treadmills that large.
Are you any more likely to win over the long term using random numbers for each draw vs using the same ones each time?
What you want to do is find the numbers that have come up the least frequently, or haven't come up for the longest time, stands to reason that they're due
They superheat the planes causing them to shrink. This allows them to run on a regular treadmill.
though the number of times you're likely to win at any particular prize level is unaffected by your choice of numbers
