http://www.tweaktown.com/reviews/68...0-4gb-strix-oc-video-card-review/index16.html
Yeah at default settings the 980 is indeed more power efficient than it's predecessors, and more so than the 290X, once you add an overclock or really stress the GPU @ stock that low TDP goes out the window
I've got a GTX 980 which sits @ 1500 core all day long for gaming, it pulls about as much from the wall as my old Titan Black did at about 1200 core.
I just get whichever card is fastest, atm that is the 980. I don't really consider the TDP in broad terms because I'm not gonna be running at stock if you see what I mean.
If the 300w AMD card is faster than the 980, than I'll grab that and visa versa if it's GM200. Once a single card can handily cope with 1440P, than I'll pick whichever uses least power at that performance level. We're just not there yet. Probably 2016 for a midrange card (Power efficient) to do really well @ 1440P imho. Then I can settle for a lower down tier card that doesn't need as much juice. (Unless I move to 4K)
+1, I won't mention it again. Just answering his question.
Great cost ?? Like 50 pounds on 400 pound card ?? PLEASE.... And from what i seen air itself works very good to. Its win win situation.
Its still better than crappy AIO watercooling that we got on 295x..
It makes me wonder with the R9 300 series launching in 2015,the GM200 based GPUs in the next month or two,the GTX960 in a week or so and so on,whether we will be still having 28NM GPUs well into 2016?
You would expect at least a 1 year shelf life for all these launches,maybe a bit longer??
Its annoying that AMD has not even got a full new midrange series out now - the R9 285 is not even fully enabled either,and the R9 280,R9 280X,R9 270X,R9 270 and R7 265 are around three years old too.
They are literally just helping Nvidia.
Lol, yeah it really is time to move on. Fingers crossed we get a die shrink by late summer this year. If not very early 2016. Hopefully transitions to other nodes won't be as difficult as moving from 28nm has been, i.e don't want to move from 28nm to only get stuck at 16nm/14nm for another 3 years
Hopefully this is a bump in the road and things will move along faster.. The race for 4K might dictate a faster pace.. I hope so anyway..
4k requires 2 things
- Monstrous fill rate
- Monstrous bandwidth
With 640Gb/s that's rumoured the card should have the bandwidth for 4k, especially if AMD have implemented the new colour compression that the 285 has, fill rate will also be interesting too!
I just wonder what will be for 8k down the line.
How many people really care about 4K though? We know AMD will be aiming for it but really what percent of the pop are really going to buy a 4K monitor.
I still can't understand the point in 4K TV's when there is nothing to watch on them. (separate grievence)
Really? See the average and peak numbers http://www.techpowerup.com/reviews/MSI/GTX_780_Ti_Gaming/22.html those are present the usual gaming, and peak periods: 229 vs 236W and 269W 271W. The only use where it is a lot more, is at video play, where it uses a stupidly high clock which is not needed.
Here's another link http://www.guru3d.com/articles_pages/asus_geforce_gtx_780_ti_matrix_review,7.html 262 vs 286W
...and another http://www.anandtech.com/show/7492/the-geforce-gtx-780-ti-review/15 372W vs 375W
In reality the 780ti used only 15-30W less than the 290X, and was only 10C cooler, but just when compared ref to ref (with the crappy amd cooler). The custom cards ran about the same temps. So the amazing and mighty 780Ti was just a tiny-tiny tad better than the hot and power hungry and monstrous 290X.
Custom cards:
780Ti gaming review: http://www.techpowerup.com/reviews/MSI/GTX_780_Ti_Gaming/1.html 230-278W consumption, 30-78C temp
290X gaming review: http://www.techpowerup.com/reviews/MSI/R9_290X_Gaming/1.html 231-263W consumption, 40-79C temp.
So with all respect, i don't think you know better than 95% of the review sites.
I bought a 4K TV specifically to play 4k PC games...
It has HDMI 2.0 and DisplayPort 1.2 so it does UHD @ 60hz and the response time is really low as well.
Panasonic TX-58AX802B
Use of references is frowned upon here, you should rely on common knowledge, advertising blurb and anecdotal evidence at all times, preferably drawn from a friend of a friend!![]()
wow 8 pages bcas of some linkedin sillyness?
or did i miss something? lol
