***The Vapers Lounge*** 2.0
Status
Not open for further replies.
So I've started vaping again. Not had an analogue since last Monday (5th Jan).
I've bought some juices from e-cig wizard as they are local to me. However, what are the must try juices? I like banana/bubblegum flavours so far. Thinking of getting some Gunpowder from Digbys for example.
My current set up is an e-go 900 and an Aerotank v2 (which I love :D - but wouldn't mind a decent battery)
I really like the RY4 mix. It has a nice taste to it :)
I so far have tried USA Mix which I found too strong and the Rainbow (which was meant to be like L&B cigs) didn't like.
I'm finding 12mb a little low for me but i find 18mg too high so i might start mixing a little bit of the 18mg into the 12mg to find a middle ground.
Must say i dont really like it at high wattage as it feels very warm in the mouth and throat so im currently at 7w.
The Protank II is really good but it does gurgle a little :)
Love being able to change the wattage on the battery and it has some very nice features too on the iTaste VV 2.
So all in all, very happy so THANK YOU all very much.
Now i got to experiment and find a nice middle ground to vape at so i can get off cigs for good :)
Good luck with getting off the cigs. I did it by introducing vaping and smoking together until vaping almost took over the smoking, then set a date in my head to stop smoking and found liquid flavours i liked. Then that date come and i stopped then. 4 weeks on Sunday since my last ciggie and i haven't missed it at all.
Do have to say that my taste did change dramatically and seam to be only able to vape good custards lol.
On the protank 2 note. Be a little wary as they do tend to leak. Great tank for a single coil setup and apparently the nature vape single coil with a cotton wick makes a good pair.
I used the protank 2 for a while but got annoyed with the leaks and gurgles so have changed it now for a Aerotank Mega and wow what a tank!! goes through coils rather quick though.
Digby's mums custard for sure!! Keep away from the kings though. Sounds nice but its just a harsh peanut butter followed by a gone off banana. oriental plunder is supposed to be a nice liquid too.
Also Mrs Lords custard cream is lush!!
Shame about The King was looking into that as a cheaper alternative to the Grandmaster which I can't afford all the time :(
Check out the OP mate, theres loads of links to good vendors there. In fact a few post ago I linked to a few good juices, that are my all day vapes at the mo... :)
E: Here - http://forums.overclockers.co.uk/showpost.php?p=27490866&postcount=1256
If you like banana then Monkey Jizz by Vaping King is a really nice vanilla custard/banana mix, and Mellow Yellow by LT Ecigs is a nice banana flavour that to me tastes a lot like the foam banana sweets. It's really cheap as well.
I like Gunpowder sometimes and sometimes I don't. It's got a weird flavour. I have to be in the mood. Try a 10ml of Hooligan if you order from them, it's a super weird flavour and tastes really medicinal, I was unsure at first but it grew on me very quickly and I can vape away on it for ages. It's quite... I don't know, complex? It's definitely a strange one and seems really marmite but I loves it.
Taste is Subjective though so what i may like you may not etc. Just Really isnt for me. Still have about 8 ml sat here may try it again after some steeping or may just throw it away lol
Vaping King FTW!
Kings Ring if you want a doughnut flavour, Queens Custard if you want a strawberry milkshake, got 100ml of each yesterday.
Vaping on his new Jammy Dodger one now and its bloody lovely!
Same here. Bought 100ml of Kings custard, Queens custard and Kings ring only this week.
Should be enough for the weekend! Lol
I do like Jester juice for when I'm in a fruity mood too.
Just bought 100ml of vape kings rhubarb and custard (new adv). Also picked up 120ml of green crack for £41 delivered. At this point I'm hiding it in boxes as I can't explain why I've got 30x30ml bottles laid about and keep buying more :confused:
So I woke up stupidly early and had nothing better to do than have a go at making a parallel coil with 24 and 28g kanthal and bunging it in a lonely and neglected Mutation X v1.
6 wraps/3mm @0.4ohm.
Do excuse the potato phone cam.
I swear this thing canes juice noticeably faster than my dual coil build, so IceShock, don't even think about it :p :D
^^^^^ looking good ^^^^^
I might twist some 32 latter and have a play with it.. But first I will need some fingerless gloves! Lol
Hahaha you know I watched rip tippers video on that build 2 days ago I was going to attempt it yesterday but decided to wait for my box mod haha. And I will be giving it a go don't you worry :P
How does it compair to a single coil or dual coil? I'm guessing it just has the clouds of a dual but looks like a single?
Just noticed aswell, one wire 24 one wire 28? The heck haha. Ain't that going to confuse or even mess your mod up? I thought you had to use two identical wires
Does anyones mutation v2 quite loudly and quite forcefully crackle, sometimes sending small globules of liquid at the speed of light? lol
I have noticed that with my v2 clone. it is the only atty that I am sometimes wary of.
Thats a good looking coil dude. :)
Some say its for aesthetics, some same it improves flavour.
https://www.reddit.com/r/coilporn
http://ukvapers.org/Thread-Show-me-your-coils?page=34
Check some of those out. Look out for lil_tuey and Justpoo on UKV, they do some crazy builds. :)
Haha, I just give it a go, 0.7ohms, 28g kanthal, 6 or 7 wraps cant remember exactly, 2mm drill bit, but @ 20w that my vamo goes to, its only at 3.9v with a fresh battery, its not got enough power to really power it, hardly any vapour coming from it.
Box mod T-Minus 49 hours, 35 mins, Couppled with some of them 35A purple efest battery jobs :)
cant wait to experiment :D
Status
