***The Vapers Lounge*** 2.0
Status
Not open for further replies.
That egrip looks lovely.
Does anyones mutation v2 quite loudly and quite forcefully crackle, sometimes sending small globules of liquid at the speed of light? lol
I have noticed that with my v2 clone. it is the only atty that I am sometimes wary of.
Mine does to a small degree, but I figured it was just what atties do/can do.
Not sure why it would be specific to an MX, as it's just a common wire between a pos/neg connection at the end of the day.
That is a lovely coil build too, very clean and professional. You will be giving Rip Trippers a run for his money soon! ;)
:D I dunno about that. Maybe if I get one of those coil building tools ;)
Ye i like it. I like not smelling of cigs and it means i can smoke in the house :)
I am very glad to hear that. Keep it up and you will feel a whole lot better in a few months, breathing better, better sense of taste and smell etc. :)
You seem to have the technique sussed, did you use a screwdriver or drill bit?
Vaping update
So i really like the RY4 flavour. Seems really nice. Got my iTaste VV 2 set at 8.0W which gives me a nice blend of hit and vapour.
ProTank 2 Seems to be holding up.
I have realised that i vape more than I usually smoke. Is this normal when you first stop cigs and turn to vape?
Just wish the RY4 was available in larger bottles- Hangsen only seem to offer it in 10ml
:D good stuff,
Yeah, hangsen ry4 is probably the best ry4, they are all different flavours, one ry4 is totally different to another companys ry4, iv tried 3 and none are as good as the hangsen one.
Eliquid world sell 20ml bottles, but it is quite costly,
I get mine from inkmania on ebay, its 100% genuine hangsen eliquid, it costs 7.50 for 50ml, (5x10ml bottles). Iv bought my Hangsen eliquid from there every time I found out about it, its cheapest place to get hangsen eliquid.
http://www.ebay.co.uk/itm/5-x-E-Liq...Health_HealthCare_RL&var=&hash=item4185be6767
It is quite a nice mod in some ways, it is incredibly light and I do like the button design, its just a bit loud in the colour department. :p
CaNsA I had a go at measuring the drop with no coil and I am getting no drop at all. I am likely doing something wrong! :o
hmmm
Try + on the firing pin in the bottom and - on the casing near the top.
What's the resistance?
I have the slowtech penny v2 with rda, and it just hit as hard when i put same rda on the nemesis.
Just took my ProTank II Mini apart.
I noticed that the coil bit was wet with liquid. Is this normal?
You mean the coil cup is full of liquid? that's just a bit of excess, if you turn your protank upside down when its all together, and then blow in the bottom of the tank, the base that screws onto your battery, the liquid will come out, the excess liquid.
If your protank is flooding a bit, make sure the chimney is fully pressed down onto the coil and that the rubber circular thing that goes around the chimney is fully pressed down aswell.
hmmm
I tried that mate and got a reading of 00.6, I get a resistance reading of 00.3 from the multi meter wires so the mod appears to be 00.3 ohms?
Cheers dude, that's about the same that I get on mine :/
The RDA has a resistance of 1ohm, which is odd
It maybe light and easy to build on, but with that amount of resistance across the whole thing it takes a fair amount to get it going when using a 0.9ohm dual coil build.
I might try a dual 0.5 ohm build and see how that works.
Does yours whistle?
Thing about that bargain basement juice is that its probs chock full of diacytol which gives you an incurable lung disease. It may be cheap but it'll be unregulated as well
I wouldn't shout too loudly, the Suicide Bunny range that your vaping tested positive for acetyls only a few months ago.
As for your comment of "proven" juice manufacturers being able to provide lab tests, then where are they because very few have or will even if requested.
Also out of the 156 american juices that were independantly bought and tested by Dr Farsalinos 74% tested positive for diacetyl and or acetyl propionyl.
So no, spending on expensive boutique juices wont keep you safe from nasties anymore then the cheaper ones.
This was the response from Pip, the owner of Suicide Bunny..
Yes, I knew about it.. Never stopped me ordering any thou.
Status
