- 11 Aug 2010
Yeah I've still got about 60ml of mothers milk left over which I'll probably just vape anyway. I wont be buying from them again and now very wary of custards/desert juices now.
OK, it seems my Protank II Mini is leaking. I've tried everything but it still leaks and I've tried many times tightening it, dismantling it and adding in even tissue to plug any gaps.... But it still leaks.
What other single coils are available? Not looking for something huge, ideally a similar size to the protank.
Cheers
Cheers
Where is it leaking from?
Like, liquid leaking out of the actual tank, around the seals of the glass?
If that's the case, then definitely send it back, iv never had a problem with mine.
(apart from once when I dropped it off of a house roof at work, it slipped out of my pocket, but I had a replacement glass with me, popped it in, bobs your unclelol)
If its leaking out of the coils, or flooding, then definitely make sure its setup right,
If its not, then send me a trust email, and if you send me a few of your old coil base cup things in a envelope, I will rebuild the coils for you perfectly the way iv done them for 18 months with 30g kanthal, 9 wraps, 1.8ohms using cotton it never ever floods or dry hits.
I wish I could see what what was happening so that I knew what to do to help right now, because its a fantastic little tank.
But like I said, if its leaking from the seal of the glass or something, well make sure its all screwed together tightly first, all the o rings are in place, if it still leaks, send it back, get a new one or money back and if its put you off the protank mini, then I guess you could try something else.
But also, if it is the standard coils that are flooding it, which I cant seem likely as that's the way its designed, but well, if you did send me some used coil cups, you could copy my build, then for the future you could make them your self, costs 3 quid for a 10m roll of kanthal, and cotton not that much, and 10m has lasted me a good 10 months, still using the same coil cup base things for my pro tank as when I got it 18 months ago.
Cheaper than buying new ones.
When i remove it from the iTaste there is no liquid on the battery so that is not where it is leaking.
Nothing coming through on the tip side either. The glass on teh exterior is dry too.
When i remove the black section which houses the coil and i look at the coil it is all wet.
Yes, all that coil base is meant to be wet, otherwise if there was no liquid there, you would be vaporising fresh air and dry silica wicks.Which would be lovely if you liked inhaling a bonfire
When you fill the tank then screw the base on then turn it the right way up ( when you turn the tank the correct way up ), don't worry that its still not full, that's because liquid has gone to the coil, the part that vaporises the liquid lol.
Erm, well, when im vaping on mine at anywhere between 10 and 13w on my vamo v6 (I still use my itaste when im out of my house), and I can use a full tank in around 15 mins. But that's because of the coil iv got built in there my self, it vaporises the liquid a lot faster, and that's when im chain vaping it.
But I just asked my missus who has the same tank, she said she uses around 2-3 tanks per day avg, when shes working, 2 tanks per day, and when shes sat around doing nothing, 4 tanks per day tops, but she always fills up before its empty, so probably the actuall average is 2 tanks per day, but she wasn't a heavy smoker either really.
Also, that ebay link looks pretty genuine to me, did the tank come in a square black box? the ones iv bought have, but it looks genuine to me, and even if it isn't, there isn't much to it anyway. and its around the same price as genuine.
Hmm, could just be a oem then, but mine say made in china, but have a picture of the tank on the box also.
But it shouldn't make a difference at all.
Is it vaping well, and is it doing its job?
And did the gurgling fix when you pushed the rubber ring down like I said a few posts ago?
Sorry for all the questions, just want to get it working right for you if it isn't![]()
Ye mine didn't have a picture on the box so probably an oem or a copy.
It did vape well but the gurgling never did go away.
I'm guessing its probably a copy which is probably why im having issues- the quality control probably is lacking....
I'm going to order a genuine one from a reputable site/seller. This one only cost me a fiver so its no big deal![]()
Yes that is what i mean
In that case i have no idea where the liquid is going. Im baffled. Its not wet anywhere else but there.
How much liquid is used when using it at 8w?
The tank goes from full to empty within 2hrs....
I did buy my protank from ebay: http://www.ebay.co.uk/itm/191406383905?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Could it be that its a copy and not the real deal?!
Cheers dude, that's about the same that I get on mine :/
The RDA has a resistance of 1ohm, which is odd
It maybe light and easy to build on, but with that amount of resistance across the whole thing it takes a fair amount to get it going when using a 0.9ohm dual coil build.
I might try a dual 0.5 ohm build and see how that works.
Does yours whistle?
Just kidding.
It was very nice actually. Have a couple of slight variations brewing too.
Tbh, I think that with the amount IceShock gets through, he should really look into making his own. It's the most cost effective way and you know exactly what's gone into it.
Ice, think about it mateIt literally takes a few minutes to knock up a batch and then it's just a matter of waiting. How long depends on what you've made.
Iirc it costs me about 80p to make a 10ml bottle of juice.
Also re. the Custard lovechild, i also add 1.5% of Dulce De Leche it makes it even better.
And Mom & Pops make a concentrate called Sticky Bun, if you mix this at 20% , then when its steeped mix it 50/50 with some ready steeped Custard its even better![]()
Cheers
That's not a fake, but it's NOT an original Kanger product, as in Kanger didn't make it. In the vaping world there's a lot of copying about, and/or the best way for someone to explain what something is or how it works is to refer to it as another product. If it's normally has the word "style" or "clone" around it, it's not the product of the orginal manufactures.
Some people don't mind, some people do.. Some style/clones are dangerous! But some do actually work better.. And finally sometimes the authentic is near impossible to get hold off, so people have to get a clone instead.
I've got my eye on a zero clone with a real dna 40 board inside.
