- 28 Oct 2011
There's a surprise...
I believe it will work as an ordinary monitor but without the benefit of freesync/gsync.Will a freesync monitor work with an Nvidia GPU? And vice versa?
If AMD wants some proper publicity, from a true expert... Send a GPU my way. Otherwise we'll have to put up with shallow rehashes of existing information like that ^^.
Do you just follow Greg around with snide comments?
Your doing a good job..
In my case im tied to a gsync monitor, cant afford new cards so monitor it has to be. Not that there are any cards worth moving to at present anyway.I don't really care, however, I don't want to be tied down to a certain GPU brand just because of the monitor that I have!
Have to agree, people want a comparison not words apon words. Pricing is looking good though.
I dislike the idea of buy a monitor based on your gpu vendor idea but such is life it seems.
Article basically was useless to me i had expected to see results and pros and cons of both .
@shankly If your going to do a good review of your new monitor can i suggest also testing with Vsync on to give users that do that a idea of how freesync might be better for them
The problem with that is I don't use vsync at all and I don't think I could put myself through a week or two using it.
I notice the input lag right away, maybe I could give that a quick review?
Seeing as I have played gaming on pc for long as I can remember with vsync off I think it's best I review against off vs Freesync.
Lovely to see AMD working so hard to bring this great free technology to as wide an audience as possible. So refreshing for a company to look out for their customers, rather than trying to stitch them for a quick buck at every turn. AMD should be applauded.
Their customers can now spend the £100 they'll save buying freesync instead of gsync on a better graphics card. A win for both customer and company!
The benefit of adaptive sync us that it is part of a standard, not proprietary.
Its of no benefit to me and half of the gaming world though is it? As 780 owner i would choose Gsync obviously, unless i upgrade to a faster amd card in the future, so all this standard does if say anyone can use it. If nvidia dont use it in the future yet its a similar price then it makes no difference to the end user what so ever.
If intel make IntelSynk to work on adaptive sync it still wont affect me.
