Sounds very eventful! I'm sad to see that you didn't quite make it to the top of Sa Calobra
Do you have time to try again on another day?I am so envious of you riding along the newly resurfaced road to Formentor!!
Do you have time to try again on another day?Sounds very eventful! I'm sad to see that you didn't quite make it to the top of Sa CalobraDo you have time to try again on another day?
My new Specialized Expert Carbon road bike shoes.
They are lighter than a pair of slippers, 230g for the pair, and the carbon sole is super rigid for outstanding power transfer.
I've been using MTB shoes (specialized Pro) and pedals (Crank Brothers Eggbeaters) since 2011 so they should improve the pedaling feel. They are being linked up to Shimano 105 5800 pedals.
I struggled with the outers using my park tools cable cutter on a jagwire kit. I should get a proper outer cutting tool really![]()
Just as a matter of interest how do Cycling shoes sizes compare with 'normal' shoes? E.g I take a size 11 in a hush puppies shoe for work but a size 12 for a nike trainer.
Just started my Trainerroad free month (came with my KK RMII) and only just realised that Trainerroad only seems compatible with a PC/Mac using a USB ANT+ adaptor and not with Android (Phone/Tablet I normally use)
Is this correct? I've got a old laptop I can use but no ANT+ USB stick and no way to mount it on my bike or have it easily near me when on the trainer (as I turbo in the back garden)![]()
Don't forget to look into cycle to work schemes if they apply to you!
I don't think they do but I will ask. TBH I don't think I'm eligible anyway as due to my job (field service technician) I have a compulsory company car and can't commit to cycling my commute at all really.
It literally is never ever checked ever.
...ever.
I wear a 9 in regular shoes, which is a 43 in Euro land, but I need a 44 for my Shimano shoes. Shimano are notorious for this. Some other brands are better, I gather.
Usually you size up one, but you're best to try a few on as each make can be pretty different.
Why is save in inverted commas?
You'll save money and essentially be getting free credit by spreading the cost over a year...
The cycle to work scheme is a ludicrous bargain. If you can get a bike you want from the shop your employer uses then it's a no-brainer.
The £500 limit is slightly bewildering, but hey ho.
I'm a bit funny with buying some stuff online due to after sales and wanting to get a feel for what I'm buying. Luckily an Evans Cycles has just opened in Norwich and Paul's Cycles sometimes has some good offers on so hopefully I'll be ok.
I thought it went up to £1000 ? I know my company allows up to £5000 now.
It is £1k usually, as that's the maximum an employer can offer without needing a consumer credit license. I was surprised by your man saying it was £500 at his place.
