Phantek Enthoo Primo front filter clips
3 Mar 2010
Right just went to open up the front fan filter and the clips are broken. I have to use double sided tape to keep the front fan filter stuck to the case. I have contacted Phantek as its a common fault with the clips but no luck.
I have used the contact us page but nothing so is there other ways of contacting them?
When did you contact OCUK and Phantek?
You can get the clips on the bay m8.
This, obviously i cant link to the auction site but google theese.
Brabantia compatible latch replacement Touch Lid bin catch spare repair clip
Bought some a while back just to have on standby, as breakage seems to be common on theese clips. Thankfully my stock ones have been fine.
Alternatively, theres a modification using small magnets on the panel that can be done. If i can find it ill add it here.:)
