***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Got a problem with my aspire mini, just seems to taste burnt all the time if I turn the battery(spinner II) past 3.8v. Not sure if its the coil bit(not sure they are genuine ones) or poor quality liquids......
mebbe time to upgrade the lot to something better....
Where did you pick up the segelei? I fancy a second one if I can find one cheap enough
£58.99 cheap?
http://puremist.co.uk/pure-mist-mods/sigelei-100-watt-box-mod
Hi
Certain coils/tanks just don't like being taken above a certain watts/volt level. yes your quite right, it is dependable on the liquard that your using too.
Bought it 2nd hand, absolutely immaculate tho, im dead chuffed :)
Also guys, my 70%vg 30%pg juice just arrived today, 2mg nicotine.
my plan was to mix it with the 6mg 30%vg 70%pg juice I got now,
which would equal around maybe 3.5mg nictotine at a 50%50% ratio.
But dang, im enjoying it as it is! the clouds are hugeeeeeeeeeeeeeee
But it definitely doesn't taste as strong the flavour as the other liquid, but meh, flavour vs fun with clouds! :p
but I will probably end up mixing it together and trying it later today once iv got over having fun with the clouds
Getting on really well with it, the motion sensor is not working on it but tbh I can do what I want on the main menu screen anyway.
Great little mod.
Cheers all
Have to admit, I am very tempted by one..... That said, I also quite like the Sigelei 100w Plus. I like the idea of dual '650's for battery life. :)
..or even the Sigelei 50w Mini looks nice...
Didnt think that VG or PG contained that stuff anyway.... Thought it was only the flavorings.
Also to add Capella do a V2 of their custard (ordered it yesterday) which is supposed to be diacetyl free.
I have their vanilla custard from alchemists cupboard, Do I bin it?
Another Q about their capella flavourings, I just got some bubblegum, strawberry and cream and some banana....I mixed some up in 10ml bottles using 20% flavour at 60/40 vg/pg @6mg and there is virtually no flavour after a week of steeping. Are they watered down?
I'm using the Ejuice me up calculator and it doesn't have an option for Ethyl maltol so I just added 0.2ml after looking at what a few other recipes add.
I'm not getting on with this mixing lark :D
Just about to pull the trigger on another genuine rose v2 @£75! I use my rose at home/social and my KF4 at work but everytime I use my kayfun now Im reminded how much of an inferior atty it really is. Im so glad I didnt by genuine like I had planned to do
If anyone is interested in an istick 50w, there's a reddit group buy going on and you can get it delivered to the UK for £35.91 all in. Just pulled the trigger myself.
I would link, but there's a big sweary in the opening post, so.... Excercise your google fu :)
UPDATE:
Authentic Protank Mini II arrived today and all is well :)
By the way, what's better: Single Coil or Dual Coil?!
Stick with single, a lot less hastle and the single coil protank 2's are better than protank 3 which are dual coils,
Also the single coils you can rebuild easy for the protank 2.
Only start with dual coils when you have a big rebuildable tank like a kayfun or a dripper
Probs needs a longer steep? Anything cream / custard related needs a good 4 weeks imo. :)
Alchemist suggest a few days, I made a custard before and it was just harsh but followed a different guide this time so I expect that to be better but the banana and bubblegum just has no flavour at all.
Guys, need some help with mixing my eliquids right.
Iv just mixed up from the bottles I have (one bottle is 70vg30pg, one bottle is opposite so 30vg70pg)
And iv just mixed up 5ml of each to make a 50/50 bottle, its not as nice as 70vg 30pg.
So, am I right in thinking that if I add this 10ml bottle of 50/50, to 10ml of 70vg/30pg.
though that would equal, 120/80 wouldn't it? because your adding 50 of each to it. if so is that exactly the same as 70/30?
im proper head blagged by this hahah iv no idea whats going on with my maths today I cannot for the life in me work this out.
But the reason im trying to work it out, is so that the 50/50 can get used up and not wasted.
Ive used Cap VC before at around 20% I'd bet they need more time. :)
What recipe are you using?
sorry if this is a dumb question;I've never made my own e juice nor looked into it. But don't the flavoring water down the VG/PG mix or is made from VG/PG, or such a small percentage it's not a consideration?
Status
