** MONITOR NEWS: 40" PHILIPS 4K BACK IN STOCK & FREESYNC/G-SYNC IPS NOW AVAILABLE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
More first for OcUK, we have the first FreeSync monitor available for pre-order, the first G-Sync IPS monitor available for pre-order and more 40" Philips have arrived:
Acer Predator XG277HU 27" FREESYNC TN 144Hz Gaming Widescreen LED Monitor - Black/Red (UM.HG0EE.001) @ £429.95 inc VAT
The first FreeSync monitor available for pre-order, based on a very unique high performance TN panel designed for gaming with a 2560x1440 resolution, 144Hz, 1ms, Zeroframe and FreeSync support.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by AMD FREESYNC™ technology
Specification:-
- Screen Size: 27" (69cm)
- Resolution: 2560x1440 WQHD
- Panel: TN
- Response Time: 1ms
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1 (100,000,000:1 DCR)
- Connectivity: 1x DVI-D, 1x HDMI, 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- FreeSync Enabled
- Speakers: 2x2W Stereo
- Warranty: 3yr (On-Site with Acer - 0371 760 1000)
Only £429.95 inc VAT.
ORDER NOW
Acer Predator XB270HU 27" G-Sync IPS 144Hz Gaming Widescreen LED Monitor - Black/Red (UM.HB0EE.009) @ £689.99 inc VAT
The Acer XB270HU not only has a IPS panel, but it can do 144Hz IPS and has G-sync support as well, is this monitor nirvana.
What makes this very interesting is that it is labelled as an IPS screen, and offers support for 144Hz refresh rate and support for NVIDIA's G-sync refresh rate technology. This is the first display featuring an IPS panel with native 144Hz refresh rate.
Offering tilt, height and swivel stand adjustments. We believe the screen to feature only a DisplayPort video connection as reported before.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 4ms response time, made smooth by NVIDIA®G-SYNC™ technology
- Complete ergonomic tilt, swivel, pivot and height adjustment with VESA mount capability for optimal placement
Specification:-
- Fully adjustable stand: tilt/swivel/pivot/height
- Pixel Pitch: 0.233mm
- Panel: IPS
- Response Time: 4ms
- Connectivity: 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- G-Sync Enabled
Only £689.99 inc VAT.
ORDER NOW
Philips BDM4065UC 40" 4K 60Hz Widescreen LED Monitor - Black @ £689.99 inc VAT
See the big picture with all the details. The expansive 40" class Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in Ultra HD. Expand your viewing experience with the monitor that is designed for the way you work.
These latest Philips screens deliver UltraClear, 4K UHD (3840x2160) pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like DisplayPort, HDMI, Dual link DVI, these new displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets. Philips displays will give you UltraClear images.
Philips VA LED display uses an advanced vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, movies, gaming, and demanding graphical applications. It's optimized pixel management technology gives you 176/176 degree extra wide viewing angle, resulting in crisp images.
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturati on and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
Mobile High Definition Link (MHL) is a mobile audio/video interface fo r directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
Features:
- Expansive 40-inch class brilliant display
- UltraClear 4K UHD (3840x2160) resolution for precision
- VA display gives awesome images with wide viewing angle
- MultiView enables active dual connect and view at same time
- SmartImage presets for easy optimized image settings
- LED Technology ensures low power and natural colors
- Slim bezel design for a stylish look
- Powerful 7-Watt speakers to unleash your content
- USB 3.0 Hub for convenient access and fast charging
- SmartConnect with DisplayPort, HDMI and VGA connections
- MHL technology for enjoying mobile content on big screen
- VESA mount allows for the perfect setup
Specification:
- Display Screen Size: 40"
- Aspect ratio: 16:9
- Panel Type: VA
- Brightness: 300cd/m2
- Contrast Ratio: 5000:1 (Typ)
- Dynamic Contrast Ratio: 500,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 3ms (GTG)
- Viewing Angle (H / V ): 176 ° / 176 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)
- USB 3.0 Hub: Yes
- Speakers: Yes (2x 7W Stereo)
- VESA: 200x200mm
- Warranty: 2yr (On-Site with Philips)
ORDER NOW
Still a little too steep for me, but I'm sure you will sell plenty at that price. Much easier to spend £430 than £600+ on a monitor. I think if you didn't take payment right away I'd pre-order one now (same way rainforest does it, but I understand why you chaps might not).
Helps that I bat for the red team as well. Is Freesync pretty much the same as G-Sync in terms of what it does?
When can we expect to see pricing for the TN version of the Acer gsync model gibbo? Got a few quid burning a hole in my pocket.:D
Nothing on the roadmap, I am guessing Asus have some form of exclusive rights on the panel, hence the Acer version being Freesync model.
The Acer G-Sync monitor is IPS, not TN. :)
Ahh, seems i may have misread the article, (cant remember it now). Regarding exclusitivity, as the TN panel in the swift is manufactured by au optronics, (basically benq) id be very surprised if we dont see a similair offering to the swift from benq themselves, something like this would slot in nicely in their XL gaming monitor range.
All the same, very impressive price on the acer freesync model. If i was using AMD cards id be all over that like a cheap suit.:D
I like the specs of the Acer Predator XB270HU a lot. It is basically exactly what I have been waiting for, but WHY is it so damn ugly? If I had AMD graphics cards I would definitely go for the Acer Predator XG277HU.
I just feel that over £500 is not reasonable for a proper 1440p gaming monitor with g-sync. Guess I just have to wait even longer or maybe switch to AMD graphics :(
How much is Nvidia charging for the g-sync module anyway? I could literally buy the XG277HU and a R9 290x and have ~£50 in my pocket. Sure it's TN, but that is not the end of the world.
Interesting and frustrating times indeed.
That Acer XG277HU makes me glad I waited to see what would happen with Freesync and respective pricing before I bought a new monitor and GPU. £200 less than the Asus G-SYNC (roughly) equivalent monitor is amazing.
Acer build quality is pants though.
Yea but Asus's monitors are very much hit or miss as well.
Spec wise, the Acer Gsync looks more attractive than the Swift with its IPS panel.
As for the Acer Freesync, I don't think the price is that great for a TN panel, even if it is a 144Hz. People are sacrificing IPS for TN in exchange for 144Hz, so why should the monitor be priced higher than the average 2560 IPS monitors? :o
