- 22 Jul 2012
- London
You gotta learn to kind of pulse it until you get the hang of being a couple of clicks from where you're aiming for
From the reviews the subtank mini (22mm) is the best of both airflow and flavour, There's also a RBA included with it. It's only just come out in the UK, I'm thinking of getting one myself but would like a few real world reviews first.
EDIT: Joyetech delta 2 is turning heads too..
Just got delivery of the new Kanger Sub tank Nano, I already have its big daddy, the 25mm.. but this little guy is giving great flavour and good vapour at 15w with the 1.2ohm coil head in it, using the same juice I have in the bigger version, this juice is a red astaire and vanilla mix, on the big tank with the .5ohm coil and 15w, I get a nice creamy vap, at 20w+ I get the fruity flavour.
On the nano with the 1.2ohm coil at 15w, I am getting the same flavour as I get from the big tank at 20w, so more the fruity side, but it is intense.
Airflow is improved, you can have 1 or 2 holes uncovered, but instead of three holes for the widest, you now get a Cyclops slot... this is a massive air draw, like a mutation x nearly wide open, its that Wide open ...
The 1.2ohm coil is rated 12 to 25 watts, I tried it at 20w and got a dry almost burnt hit, but at 15w it is fantastic.
Got the Subtank mini yesterday i'm really impresse with it, lots more flavour than the atlantis and i'm not noticing any less vapour, but i did have one major problem though, unscrewing the RBA deck to have a gander and the bit where the threads are just fell apart and a piece of the internal shaft fell on the floor and i can't bloody find it, and then the insulator and thread posts all came apart i would have usually blamed my heavy handedness, but it just fell apart in my hands... can't be arsed to take it back, so will just wait until a spare can be bought or something... i dunno
A mate of mine uses the Subtank and he concedes that the airflow isn't as great as the Atlantis, but the flavour is amazing. Also, where did you see the Subtank with the "Cyclops" air slot?
I've been using a Mini Protank 2 for a while (from myepack.co.uk) and find that quite often they leak down onto the battery. Any fixes for this? Also can the coils be rebuilt? How do you go about that?
Just be aware of the insulator on the Subtank. Its got a habbit of disintergrating with tank cracking juices. Kanger are aware of it and are fixing it.Thanks for the comments guys. The Delta II looks like it could outperform both the Atlantis and the Subtank! The only issue is that it's not out yet, and it looks like the RBA base is sold separately.
Nature of the beast, air holes in the 510 connector.I've been using a Mini Protank 2 for a while (from myepack.co.uk) and find that quite often they leak down onto the battery. Any fixes for this? Also can the coils be rebuilt? How do you go about that?
Yet said it a few times, to me its Germolene. (the old pink antiseptic cream)Just tried out Digby's Hooligan... WTF is that supposed to taste of?! Reminds me of the smell of savlon![]()
Yet said it a few times, to me its Germolene. (the old pink antiseptic cream)![]()
Product Description
Hooligan, our latest concoction. Its sweet with a lingering tingle. Cherry, lemon, Oranges and Limes combined with a bit of fizz.
I've also had this problem. Starting to think i might be due something new, any recommendations? I dont want anything too fancy/complicated i still dont understand all this variable voltage stuff/ohms etc
I thought they fixed it with the new mini tanks? The insulator on the mini RBA is clear instead of white.
