***The Vapers Lounge*** 2.0
Status
Not open for further replies.
If I had a KF, I be using all the time to justify the cost of the thing :)
It's only a clone. Don't get me wrong it's definitely better than the nautilus, it's just the difference isn't currently enough to stop me being lazy! I got the Nautilus because I broke my collarbone and couldn't move one hand for a bit so I decided to get a replaceable coil tank as all mine were pretty old and dreadful. I just found I really like it.
I'm still using drippers most of the time at home but I really like the Nautilus for convenience. I've noticed that there's a lot more in the way of great easy maintenance tanks around these days which can only be a good thing. Really impressed with the EMOW starter kit I got my mum, it's way better than the EVOD kit I started with.
They do different colours too like black and white - I myself prefer the tiffany blue version it looks really nice.
Bear in mind though with the LPG it's a hybrid mod with an extended lip (the atty slides inside the mod so airflow from the bottom will be an issue) so ensure your atty will get appropriate airflow before buying it.
Went for a 4nine mod 18350/18500/18650, only 8 pound! :D
How long would a 18350 battery last with say a nice little dual coil at around 1ohm?
Edit: just got a tape measure out, the 4nine mod is only as big as the actual battery! haha, so ill probs just run it with a 18650 efest in it. didn't realise how small mech mods are!
Also, right iv never fully understood mech mods to my understandings is this.
Right so, say I take my 0.3ohm dripper and put it on this mech mod with a 18650 efest in it, it will run at 3.7v.
On my sigelei box mod, right now im running 40w which is 3.7v anyway, so the power ill be getting from the mech mod will be around 40w?
And you know when the batterys dying because you wont be getting as much power and vape from it?
Am I right in thinking all that there? :p Cheers
Pretty much. ALWAYS check your build on an ohm meter first before putting it on a mech. Using ohms law calculate the current from the resistance & peak voltage from the battery to ensure you don't go over the battery's amp limit.
You will experience sag which should tell you when to replace the battery.
I will do :) cheers
Damn slow fast tech, haha im excited already, I think im getting excited 3 weeks too early though.
Stream engine says using an efest 18350 700mAh, with a 0.4 ohm coil will last 5 mins total vape time aka 54 lots of 5 second drags.
Here is some of the gear i have. Unfortunately the Hana Modz clone (top left) battery has completely died so it doesn't work until i get it fixed.
Of all the bits here I only use the Dovpo DT50 with the Kangertech Subtank. It really is an awesome combo. Plenty of flavour and vapour from the 0.5ohm coil.
Just want to put up a quick post about the guys from Angelfiremods, I had a bit of an issue with a magma clone from them and after a few back and forth emails and sending it back once it still wasn't right.
They were driving by my home today and offered to pop by if it wasn't much trouble and look at the RDA together, so I've just got back from meeting them and well there customer service is excellent. They agreed with the problem, left me the attomiser, chucked me a couple of others bits and still offered to refund me (I refused).
If you are after something do consider them, with that kind of customer service you cannot go wrong.
There was a delay sorting out some BVC coils for my order from them and they'd missed the outgoing post, so they hand delivered it to my door.. 34mile round trip.
So I totally agree with you, they care and that's a rare thing these days.
I bought a Kayfun V4 clone and no matter what I do, I can't get it to vape properly. Tastes burnt all the damned time. I have the cotton correct (not tight but not loose), I have it against the walls and not covering the holes.
Any suggestions? I have reverted back to my genuine Kayfun 3.1 and have never had an issue.
I totally covered the holes Gregg. No problems at all but tbh I found it average at best. Not a scratch on the rose
Exactly the same problems I had with my kayfun v4. After a day or two making numerous coils and different amounts of cotton I give up on it. It doesn't work at all. It's a shame as I was looking forward to it a lot aswell lol
Status
