From what I can tell, most RBAs are based around the KF anyway or very similar, there is a learning curve with every device before it will give you the best performance.
Having said that, the lemo drop is cheap and easy, heck I've even used it as a dripped the bore on it is rather large.
EDIT: could it be the cotton your using that resulting in dry hits?
