OcUK Staff
- 26 Nov 2014
- Stoke
It's here. The worlds FIRST certified 2000W consumer power supply is now available to buy exclusively from Overclockers UK, and it has the 8Pack seal of approval. This SuperFlower PSU is absolutely ridiculous, it sports an impressive 80+ Platinum 230V EU rating, it is probably the heaviest consumer PSU i've ever picked up, the modular cable braiding is spot on and it will run a hugely overclocked tri/quad SLI or XFire setup without breaking a sweat, as 8Pack will show you below
SuperFlower Leadex Platinum '8Pack Edition' 2000W Fully Modular "80 Plus Platinum" Power Supply - Black @ £349.99 inc VAT
The collaboration of SuperFlower with the world's number 1 overclocker, the multiple world record holder 'Ian "8Pack" Parry' has led to the worlds first consumer 2000W power supply on the market, offering extreme power without compromises, the 8Pack way! This Power supply can handle 4-way SLI & 4-way CrossfireX with ease, and with efficiency levels of up to 94% to boot.
All Leadex Platinum Power Supplies feature a fully modular design, 140mm silent DBB Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
For when you need the very best and biggest power supply on the market, the '8Pack' edition 2000W Superflower 80+ Platinum should be your first and only choice.
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Platinum Certified, 92% 94% 90% Efficiency At 20% 50% 100% Rated Load
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications
- Dimensions: 150 x 86 x 220 mm (W x H x D)
- Fan: 140 mm DBB(automatic control)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 94% (230V), 80 Plus Platinum certificate
- Form Factor: ATX12V 2.2 / EPS12V 2.92
- Power: 2000W
- Active PFC
- 3.3V: 24 A
- + 5V: 24 A
- + 3.3V & + 5V combined: 120 W
- + 12V: 1999.2 W / 166.6 A
- -12V: 6 W / 0.5 A
- + 5VSB: 15 W / 3.0 A
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-2000F14HP
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 8-Pin EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-pin PCIe
- 18 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Only £349.99 inc VAT.
ORDER NOW
Features
Specifications
- Power: 2000W
- Active PFC
- 3.3V: 24 A
- + 5V: 24 A
- -12V: 6 W / 0.5 A
Connectors
- 1 x 8-Pin EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-pin PCIe
- 18 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
ORDER NOW
