Unless it was on a stone tablet with hammer and chisel then no.Wrote a lecture, does that count?
Carried on with the kitchen, fitted some under cupbord lighting, just need to fit the sockets in the back of the cupboard tonight.
oooooo. I have been looking at fitting under cabinet lighting in our kitchen but couldn't get my head around how I am going to hide the wiring so up to now I haven't bother.
Do you have any more details ?
You say you are fitting sockets in the back of the cupboard
1- - how are you getting power to the socket ?
2 - will the socket be visible when you open the cupboard or is it going behind the back panel of the cupboard ?
3 - are you going to have to take the cupboard off the wall to get the back panel off ?
My back panels only seem to come off from the back which would mean removing the the cupboard from the wall which isn't realistic.
If you manage to take any during and after pics that would be handy.
also where will the switch be to turn them on ?
Before it was plastered i installed a mains feed which would then be drilled through to the back of the cupboards and into a socket inside, i wasnt really sure what the plan was going to be at this point but thought it was a good idea to have some power going into them just incase i needed it. This was quite lucky as i forgot about the power for the extractor fan
http://i.imgur.com/Bt0gZEu.jpg[IMG]
When you open the cupboard you will be able to see the socket, the on off switch at the moment is going to be controlled by the plug but after ive finished the tiling and little utility room i will be installing a PIR and timer. As they are LED i'll probably set it to an hour and leave them on forever[/QUOTE]
Damn :( I thought you had some clever trick to take a feed off the socket below.
My wall is tiled up to the cupboard as well so that makes it even harder.
I don't fancy cutting a big hole in the back of the cupboard either, it certainly wouldn't go down well with the missus :D
bought some lining paper for doing the bedroom walls before painting.
http://i.imgur.com/vU11tro.jpg[img]
Should get things started on Sunday after sorting out my photos from the football if it goes ahead![/QUOTE]
Buying something isn't a man job. Post back when you've done something with it!
Does this kind of stuff really have a place in this thread!?
About as relevant as this pish you're writing.......![]()
