- 20 Jun 2010
We save all our tesco carrier bags from deliveries and have a scoop
Eww, these have holes in. Or does kitty already do a good job of treading litter through the house? heh.
But it will, it will...Why not flush the solids? I can't see any reason not to.
Surely it must be better than sending all those plastic bags to landfill.
We use recycled paper pellet litter, and the weed on stuff goes into our compost bin, where it is currently stubbornly refusing to rot downBut it will, it will...
waste water or bury plastic... lose lose.
GEt some biodegradable poop/paper bags and bin/compost it
Green or grey bin dependent on the bag you use.
Scoop out the bad and change when the cat does a big wee (and change reasonably regularly anyway)
When we had cats we scooped the poop and the clumps of urine every day, put them into bags and put them in the normal rubbish bin.
Poo can be flushed down the loo (even though some say you shouldn't)
Wee you can scoop out that bit and chuck it in the rubbish bin.
Get some dog poo bags to put it in, and put it in the outside bin or it will whiff.
The more expensive litters help with the smell as well. I use catsan.
We use the Sainsburys value baby nappy bags, as they are the right size, have an element of anti-odour and tie up easy for disposal![]()
My dog eats it. :/
We use:
http://www.zooplus.co.uk/shop/cats/cat_litter/cats_best/14001
We wen't thru a fair few different brands before settling on this, the 40L bags last an absolute age. Yes its more expensive but you dont waste nearly as much as other stuff, and even the litter itself can be flushed down the toilet.
It prevent odours very well whilst not being perfumed, it doesn't seem to track anywhere near as much as the Catsan mentioned above and it clumps very well. We have a huge litter tray under the stairs, gets filled about 3-4" deep. Scooped out every day and topped up whenever needed.
I like the litter that clumps into balls, as I find it a lot less messy than the none clumping type.
I believe this is how the Asda Smart price ones are made..
