- 19 Feb 2007
- Northampton
Anyone done this on a 980 ? Just wondering what the temp difference would be on that.
I think similar to gtx970.
Thats a pretty decent temp drop. Tempted to try this on one of my 780's. Top card in my sli setup can run upto 20c hotter than the bottom one, (85c vs 65c). Of course some difference is normal in sli, and theese are non ref cards. But may be worth a shot even if it is only a few c.Was reminded of this thread as I went to re-paste my GPU earlier with my ICD I had from awhile back. It's a replacement GTX 780 I got after I had to RMA mine. I noticed it was running a bit hotter than my last one, then I found out why
No paste on part of the core at all! ICD on and temps down 9C. Had a similar sort of drop when I had it applied on my 6970 a couple of years back too. Good stuff![]()
did you go for it? Dicehunter?
harry5522, could you resize those images or place in spoiler tags please. Thanks.
