*** Destiny Raid & PvP discussion thread ***
CE:HM Tuesday, 20:00
1. Schnippzle
2. thoseion - 32 Hunter
3. EvilMatt
4. WriteThatD0wn
5. Ehhh Mazin
6. Chris M135i
We all good for tonight? What characters is everyone thinking about bringing along? The missus is away most of the night so, if we finish HM super quick, would anyone be up for a quick NM as well?
I'll be on from about 18:00 for Nightfall/Weekly if anyone else is around for that.
Should hopefully be back about 19:30 and have a 32 titan or warlock to use depending on group diversity.
If people still need raid secondaries/primaries we should really run NM first as we will lose the chance doing HM first, I guess it depends if we think we can get it out the way really quickly?
Will bring one of my hunters, definitely up for a normal mode after if there's time (probably on my warlock) in hopes of a black hammer. If not I might look to see if we can arrange a normal mode run later in the week for a shard run (and a bit of relaxation after the hard mode frustrations)
I can move it to 8pm, I just try to push it earlier if I can cos I'm an hour ahead :) gives me time to do Nightfalls and bounties beforehand
Tuesday 8pm Crota's End Normal PS4
1) middgen 31 hunter
2) OweO - 32
3) Tibbz2 - _Sgt_Angle 30
4) BF-Bert - DavieM66
5)
6)
Still a couple more...
2) OweO - 32
5)
6)
I can probably be on from half 7.
I don't need anything bar the HoC from the Crota checkpoint itself. Just depends what everyone needs.
Are we looking to run bridge properly or cheese quick run?
1. Schnippzle
3. EvilMatt
4. WriteThatD0wn
5. Ehhh Mazin
6. Chris M135i
I'll be about if anybody drops out
Quick run is fine with me....if we have 30s on board might as well cheese it...
Although I do like to do it properly when I'm running my main, most interesting part of the raid :)
8pm has worked out better actually as I can get the run done with my work colleagues at 7 :)
I'm happy doing it in either order. I want to take my Titan through NM and Hunter through HM. I have all the secondaries already so it's really just a Titan helmet I'm looking for, but if peeps are still hunting secondaries I'm happy to do NM first.
Cool sounds good. :)
I'm around for most of the night. Could do a Normal run as well as I still want Hunger of Crota but I'm in no rush for it. My Warlock could do with some armour pieces as well.
I'll probably be loitering on Destiny from around 5pm, inv me for weeklies whenever you get on :)
Need around 18 shards to get my Titan to 32. Fingers crossed for this week.
I'll be loitering as well, don't mind doing a NM with my warlock and then HM with my Titan. Need that blackhammer (and three pieces of raid armour for my warlock) :D
2) OweO - 32
5)
6)
I'd be up for this now the time has been put back. 31 Hunter PSN ZeroSight. Think that makes atleast 3 Hunters in the party so if you want to mix the classes up more then no probs and I'll do it later in the week. :)
2) OweO - 32
5) ZeroSight
6)
No worries, doesn't matter too much about classes on normal mode :)
2) OweO - 32
5) ZeroSight
6)
ok cheers. Now I've got a decision to make. Use my max One Way Ticket with no tracking or use my HoC that I got last night with tracking just unlocked.
2) OweO - 32
5) ZeroSight
6)
If you want it doing properly I could try and level up beforehand
Nah don't worry, I'm just looking to blitz the raid a couple times tonight.... :)
I would use the HoC with tracking, DPS doesn't need to be that spot on on Crota. 32 sword bearer and he goes down easy enough with patience.
HoC definitely for me. Much better to have a guaranteed, slightly reduced damage hit, than have the odd rocket go sailing past Crota!
Fair enough, might end up leveling up anyway if I happen to find some helium filaments somewhere :p
Net is a bit shaky but i can play crucible without too much trouble so hopefully playable tonight!
Finally got raid helmet for my 32 Hunter (currently using exotic helmet).
So both my characters have full raid gear now. Bad news is that I now need 105 radiant shards to level both sets of raid gear to max, which will mean weeks and weeks of raiding for materials.
I have about 500 ascendant shards sitting there doing nothing. I wish I could trade them for radiant.
Good news is I managed to get 3 exotics today, 1 from nightfall which was a warlock chest which I already have so sharded. 2 from NM raid Truth from deathsinger and Red Death from Crota. Already have maxxed out Truth so I have put the second in the vault and I may use with my alt or break it down should I require shards.
