Are there any reviews out that actually compare the 8GB vs 4GB 290X?
July at latest I read elsewhere on here.When is the 300 due ?
Was thinking of a 970 until recently, and now back to the AMD campQuestion on the PCS+ cards: will 2 be ok in xfire with 3-slot spacing?
I currently have an XFX gold 750w psu which is not enough to run crossfire 290s. If i get the 1050w model available here, can i simply swap the psu unit and keep my cables from my old psu in the case?
Cant be arsed changing all the cables again.
Ordering a psu for two of these 8gb can someone link me to one suitable please?
ksaplostras @ Overclock.net | 14th January 2015 said:Setup :
2x R9 290s in crossfirex both with Corsair HG10 and H75 in push/pull with corsair SP120 ,
overclocked 1100/1300 at stock voltage.
As you can see at the photo i use the rads as exhaust and i have 3 corsair AF140 as intakes
1 at the back and 2 at the top.
The temps at both gpus are 60-62 degrees running valley or gaming (BF4).
The vrm temps on the top card are 81Vrm1 and 65Vrm2 while gaming and 4-5 degrees lower
at valley bench.
The vrm temps on the bottom card are 88Vrm1 and 67Vrm2 while gaming and 4-5 degrees lower
at valley.
The blower fan on both cards is at 35% speed.
If you could, extremely difficult to find as it just throws up 4GB versions in google
Yes, though I can't find any PCB pics of this either, the fact its the reference 290x blower cooler is enough to tell me it is the reference 290X PCB, could always quiz gibbo as he had those made just for OcUK
General rule of thumb for GPU water cooling: Buy the cheapest reference cooled card you can, as 99% of the time it guarantees block compatibility.
Any news from either of you?Will see what i can do mate. If i can't get one, then I'll take one of my cards Sapphire 290X 8GB cards apart to grab a picture.![]()
http://forums.overclockers.co.uk/showthread.php?t=18653304
Gibbo seems to allude to the fact that it should work...
