Which NVIDIA GeForce GTX 970 model would you go for?
25 Sep 2011
Staffordshire, UK
I just put a strix in and really like it. No coil whine that I can tell and auto fan shut off at less then 60 degrees.
If the price difference between them isn't an issue then the EVGA FTW ACX. Fantastic warranty as well, they were the first to offer help to customers wishing to return their card.
Otherwise I'd just go for the £260 Zotac which I believe has 5 years extended warranty as well.
I had two Gigabyte G1's and they were silent, even at high FPS or load.
If your set on the 970 and as far as 970's go I couldn't fault them*.
*as far as a single card for 1080p gaming goes.
I'd agree. Neither of mine had even a hint of coil whine and were very quiet. They perform very well...if you're not bothered about the vram.
whichever is the quietest at load you won't notice a few fps unless your monitoring it but you will notice a few decibels
I believe it's only available on Overclockers and as a website, they're too expensive (and £9 minimum shipping when most other websites offer free shipping when you get to the £300 price level) so I won't be choosing that model.
Another 76 posts and you'd get free shipping from OCUK anyway, would you not? It's worth the little bit extra for the quality of service you get.
