Same card for me.
I’ll be transferring from a 4Gb card in current XL, I’m getting the new XL with MM preinstalled. What’s the best way of transferring current stuff to new 32Gb card and getting MM on there as well?
Carrying over an existing NNID & games etc to the new one you will need to use the system transfer tool. MM should copy over but if it doesn't you'll see it on the Eshop to download free.
In contrast I'm expecting a simple cut and paste will do for me because I'm not migrating from a current 3DS - I'm coming in clean - just want the better micro SD card in and I'm done.
Oh Crap, so we have to copy from the memory card in the new 3ds to the new bigger memory card even though they are both brand new?
Guess I need to get a memory card reader for PC
Do you mean do a system transfer to the 4Gb card that comes with the system, then transfer everything to the 32Gb on a PC?
I would have said do the system transfer on the stock sd card - then once that is done do a cut and paste from that card to your new samsung card - then with the new card in the new 3ds go to the eshop and it'll be there to re-download (unless you get lucky and the game has somehow copied over).
I've got the following lined up:
16GB Samsung Evo transplant
A Link Between Worlds (digital download code in my inbox all ready to go)
3D World (physical)
DK Country Returns 3D (physical)
And Majoras Mask obviously pre-installed on the unit.
Meez excited.![]()
3D World (physical)
Meez excited.![]()
Ah I didn't know! So you can buy ecodes for latest games from sites and redeem them on the Nintendo store? So games like the latest Pokémon games etc?
Nintendo store put charging cradles up for pre-order for N3ds and N3dsXL, they cost around the same as a normal charger.
