Great work with drilling those holes. It's a very nice finish you've attained there by the looks of those pics.
I have a "standard PSU" or close to standard, a Fractal Design R2 750w its 140mm and there is NO room between GPU and PSU, I have also looked at that Silverstone SFX-L PSU, it would be a very tight fit with my EVG 970... not sure if it would fit actually. 1cm, maybe with that flat cables, i could mod the included PSU stand for a few extra mm
Nice job, done any temp testing yet?
Hello Telecaster ,not yet ,only just finalised the build in the last hour , Dust filter on the side window i may install ,
i am really tempted in Pre-ordering Silverstone SFX-L 500W '80 Plus Gold' Fully Modular Power Supply ) 130mm depth & zero rpm tell 41c
, or maybe Silverstone Strider SFX 600W Fully Modular '80 Plus Gold' Power Supply (SST-SX600-G) ver 1.1 no coil whine or fan sound ,
also will replace the ZOTAC GTX 970 & try out my Gigabyte GeForce GTX 970 "Mini-ITX" 4096MB
To end this Project i want to do some fine art on the case
I think the Silverstone SFX-L would be a perfect fit with the Mini ITX GPU, go for it. No need for the 600w sfx that is a lot more expensive and probably louder. I would buy it myself if it would fit with a 25 cm GPU... not sure. Post some picture of the PSU in the case - i would appreciate it. Im using a 750w standard PSU right now, can only fit it with the air intake towards the front plate.. I´ts a non modular. I ordered a Be quiet 400w before i bought the gxt 970, returned it to the reseller, they will not accept it... they say someone has opened it?! I haven´t for sure opend it! think it would work with the 970?
I now placed a order for the Silverstone Strider SFX 600W Fully Modular '80 Plus Gold' Power Supply (SST-SX600-G) ver 1.1 zero rpm tell 45c & no coil whin they say . but yep the Silverstone SFX-L would be great psu also , a lot of stores do 14 day returns , strange ,even if it was open & you found its not to your liking/change of mind .
the Be quiet 400watt should run the gtx 970 fine ,a 970 underload uses only around 164watts upto , there are many Sites that offer a Total Watts Calculate Like coolermaster here
Good luck with that PSU, there's a 65 page thread for it on [H] and I think 64 pages of it are full of complaints about the noise from it. I think a few people have fluked a golden sample which is quiet, but most are noisy.
The main problem being the fan, it's a 12v fan being massively under volted hence it makes silly noises whilst trying to start up on low volts, pity they can't fix this issue on such an expensive PSU, it's not like it's a budget piece of kit.
Unfortunately for a lot of people it's the only option for really small cases with decent power requirements.
Very sleek looking build. I'm quite partial to mini itx PCs so thumbs up from me.
