So a few weeks ago I suffered a HDD failure in my 10TB RAID 5 array. That issue has now been resolved but the following symptoms have remained:
1. File transfers are only going mid-speed and tend to hang at the end for a little while
2. The MegaRAID interface takes a while to connect to the Perc card
3. On boot, the MegaRAID interface screams hell about the fact the Perc card's battery has apparently failed
The weird thing is though, when you actually look in the log, although the battery does indeed have issues on startup, it then proceeds to charge fully up and have no issues whatsoever later on?
Looking at it now, MegaRAID says the batter state is "Optimal" with a charge of 77% (has been on for weeks - is it normal for it to not be 100%?).
Should I replace the BBU, or would I be wasting money?
